Question about Kenmore Elite 45986 Front Load Washer
Kenmore washer 110.44832200 When machine is setting, water slowly fills to door level in 2 or three days. Any idea on solution?
Stephen Lam
    President:
  • 670 Answers
If it is filling up with water when the machine is not on, it sounds like the water inlet valve is leaking. Normally no water should enter the machine if it is not running. It is a relatively easy repair. Just remove the hoses from the back, remove the back panel and it the part where the hoses attach. You can get a replacement part from your local appliance supply house or online such as www.repairclinic.com. Hope this helps you.
Posted on Feb 12, 2011
Testimonial: "Thank you very much. Sounds very likely to be the problem. Going to pull machine from wall and give it a try. I needed that tip to get started! Thanks"
I have a washer FAFW4011LWO model number and it turns on and starts filling with water and stops after 3 seconds. I have replaced the door lock and it is still doing it. Any ideas?
maybe plugged screens in fill valve
ck here.....
https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Washing-Machine/43-2-832628-/new/Frigidaire-Washer-fills-slowly-or-will-not-fill-at-all-FAFW4011LW0
Jan 05, 2018 | Washing Machines
Just got a Kenmore he washer and dryer I'm wondering why my washer does not fill with water to cover the clothes
Either the fill valve is not working or the controller is not sending a signal to fill valve to open. If parts needed check here Search Over 2 1 Million Appliance Parts
Sep 10, 2017 | Kenmore Washing Machines
Washer didnt fill when turned on, but filled when holding "reset"
sounds like your water level switch is bad OR the small hose that goes from the waterlevel switch to the bottom of the tank has a hole in it.Try replacing this small hose first.you can go to an auto parts store and match it up.it's usually about 3' long and about 1/4" inside diameter and about 99cents a foot.
Aug 26, 2009 | Maytag Ensignia 3.3 cu. ft. Top Load...
Kenmore 80 series washer will not stop filling up
one of three things,inlet water valve bad,water level hose came loose or water level switch is bad,check all tree and let me know-mike
Apr 14, 2009 | Kenmore 24902 Top Load Washer
When not in use, my washer begins to slowly fill with water.
you either have a very poor water pressure to the machine or the fill valve is not closing completely and will need to be replaced.
Mar 19, 2009 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
We just purchased a top load Kenmore 800 washer machine. We have washed 2 loads of clothes and Now it has stopped filling up with water. It will not do it to wash or to rinse. We have gone thru the mannual...
The first thing seems to be the timer,or the water level switch. Try filling the washer with water by hand, if it starts to agitate after being filled its the timer, if not it is the water level switch, let me know if you need further assistance.
Mar 13, 2009 | Washing Machines
Kenmore 80 series model #110.26882503 fills slowly
Yes, the only other thing I would do and you may have done this is to put the hose directly over in the washer tub and turn the water on to check the flow. If that's good then replace the water valve.
Dec 08, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore Elite Model 45992
This is usually an indication of a defective water inlet valve (also known as a fill valve or mixing valve). This is a fairly simple repair that you can perform yourself. If you can post back with your complete model number (located around the door opening), I can track down a part number for you.
May 20, 2008 | Kenmore 4292x Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
Michael Thomas
Michael Thomas
Paul Carew
Lawrence Oravetz
