Question about Hobart Slicer Automatic 12"
Had motor fixed witch way does the blade run?
Posted by carlccamelot on
vestxre
    New Friend:
  • Hobart Expert
  • 120 Answers
Counter-clockwise.
Posted on Mar 15, 2011
I have a delta table saw, Model 34-670. Blade no longer turns. Motor "runs" producing a high pitched whine, but the shaft is not turning. Is the motor toast or is it something that can be fixed?
CAN YOU SPIN THE BLADE WHEN THE SAW IS NOT RUNNING , CHECK TO SEE IF THE MOTOR TURNS WHEN YOU DO THIS . IF IT SPINS YOU NEED TO RETIGHTEN THE BOLTS HOLDING THE BLADE IN PLACE CHECK THE DRIVE BELT IF IT HAS ONE FITTED.
Oct 26, 2018 • Delta Saws
My saw smoke whencut n wood
With the saw unplugged, look at the blade.
1) Is the blade black and charred?
2) Smell the vents at the side of the motor, does it smell burned?
Changing to a sharp blade will fix problem #1. Push the blade into the cut slower, keep it straight (no cutting curves), and maybe set the blade to a shallow cut and make several passes.
If the motor stinks, check to see if there are violent sparks coming from the motor when running, if so that's an indication you should get another saw. Done!
Oct 19, 2017 • Saws
2answers
Why is the blade on my black and Decker edger spinning backwards and how do I fix this
if its spining backwards the blade is up side down motors dont run backwards they run clock wise your blade should run clockwise to its possible they put your blade on backwards you will hgave to flip it put it back on
May 18, 2014 • Garden
I have a 1999, Chev Venture. The wipers quit working, but i can still hear and see the motor run. Will i need to replace the motor or is there a fix for this?
My guess would be something broke in the linkage between the motor and the blades/arms. You may have to remove the blades and pull off the trim panel to find out.
I have installed the 66 cc motor kit and have come across a problem with the CARBURETOR no gas is making its way to the motor
hello sir, mower will not start or run, does it have good spark,good compression,or only runs on full choke,engine surges up and down, are you getting fuel to the engine if not try this, your carb. is clogged up here is what you can do for a simple repair and other things if you want to, you will need a new air filter,spark plug, oil, if you want to a new blade also ,sears has a mini tune up kit that you can buy. now for the carb, empty fuel tank, place mower on side to where carb is facing up place a rag under carb to catch excess fuel,remove the bowl nut and bowl careful of the gaskets,now spray carb cleaner in the small port holes in the carb steam in the middle of the carb until clean,now spray the bowl nut holes until clean there are three,after cleaning put bowl on the same way you removed it with dip towards front of float,put bowl nut in, now while you have mower on side drain the oil remove filler cap to drain,put pan under spout,mower holds 21 o/z of 30 wt oil,you can remove blade to get sharpened or put new one on,to remove blade put a pair of vice grips on the body where the blade can stop and not turn it is usually a 9/16 or 1/2 socket, put blade on add oil,add new and fresh gas,you should be good to go,hope this helps,what i am telling you here is what i would do if it was here in the shop,any comments welcome,thank you.
Feb 07, 2012 • Garden
7helpful
Loose blade, motor still running blade not moving.
Its a fault with these machines. The blade is fixed on a plastic mounting (the black hemisphere you can see on top of the blade) and this seems to wear quite quickly. So the blade is not fixed to the shaft! To fix - you have to access the end of the motor shaft. To do this, pull the base out as far as it goes(15-20mm) insert a flat screwdriver into the barbed flaps on the central plastic shaft and push gently to release (not the easiest of jobs!) once released you should see the end of the motor shaft with a flat slot. Now, you can unscrew the capping nut holding the blade. I replaced the blade assembly with the following: First, 15mm OD washer with 4mm hole onto shaft. This should sit on the shaft at the bottom of the thread. Then the blade. You'll need a washer that sits into the hole in the blade to center it on the shaft. This washer needs to be slightly thinner that or the same thickness as the blade. Thesn another 15mm washer over this followed by a lock nut or cap nut to secure. This worked perfectly for me.
1helpful
Staples(Fellowes?) micro cut shredder - blades not turning
Sometimes the main gear is attached to the motor with an ALLEN SET SCREW
98 ford expedition wiper problem
check the transmission assembly at the motor it may be stripped or a c clip came off
Hobart Slicer Automatic 12" Logo
Top Hobart Kitchen Appliances - Others Experts
vestxre
Dennis Boxerman
Michael Thomas
Michael Thomas
Are you a Hobart Kitchen Appliances - Other Expert? Answer questions, earn points and help others
