Question about Dryers
I am looking for a part for our dryer. (Start Switch)
Posted by lmyers2300 on
Anonymous
    New Friend:
  • 91 Answers
Look on-line and type in your dryer and part needed.Locally you can go to Sears or an Appliance repair center.
Posted on Feb 12, 2011
Why want this dryer stay on ?
you have a bad belt switch,if the dryer stays running while you hold the start button on and stops when you release the button its the belt switch part WD21X10261 i've seen this a few times,go here and look at part 803 this is the bad part.
www.searspartsdirect.com/model-number/DPXR473EW0WW/0432/0151200.html
Oct 03, 2017 | GE Dryers
Dryer won't start when start button is pressed
does outlet have power? if yes check DOOR SWITCH look on door for door switch lever then on dryer were it will hit switch. you can try to press it with a screwdriver or something while turning on sryer start. also you can bypass the switch by taping the wires together and see if it then works. switches are cheap.
Jan 25, 2014 | Maytag PYE2300AY Electric Dryer
Dryer light stays on when door is shut nd wont run
check the door switch,i don't work on lg but on any other dryer if the wsitch is broke the dryer won't start and if the light is on the switch shuts off the light and dryer will start.if you send the model number i can look up the switch for you.open the door and look around the frame where the door closes into,there should be a push button switch or a little paddle that the door hits,when you push in on the switch it should make a clicking sound or i've seen the paddle broke off.hope this helps or if you removed any wires to the door switch you might of wired it wrong
Mar 30, 2013 | LG Dryers
Dryer won't start
First, let's look at the switch on the door that is supposed to not allow the dryer to start if the door is open.
If this switch fails, could cause the problem. (Somewhat common)
Second, the switch that is supposed to start the machine could have failed. (Not too likely)
Then check the circuit breaker in your "fuse box" in the hall or garage or basement or wherever.
Circuit breakers can trip and not look like it. You might switch them (there are 2 together) on and off a few times to see if that is the problem.
Be blessed.
Feb 18, 2013 | Maytag Dryers
After 500 kenmore dryer is done drying the dryer won't shut off
The push-start switch in the dryer is probably bad. The contacts inside the switch get warped over time, causing the dryer to think you pressed Start again after it finishes a cycle. Replacing that switch should solve your problem. You can find the switch online at PartSelect.com if you know take the rear panel off the dryer and see what the switch looks like.
http://www.partselect.com/PartSearchWizard.aspx?Appliance=Dryer&Brand=Kenmore&PartType=Switch
Nov 06, 2010 | Kenmore 500 6952 Dryer
Dryer will not start
ther are alot of things that wont let these dryers start. the start switch the timer. the door switch. but maybe you havent tried the motor switch. this is built with a GE design. if the belt isnt hooked up the idler pulley will not activate the switch. if you get inside the dryer. the motor sits to the left. the idler pully sits right next to it. if you look at the base of the dryer where the idler makes a 90degree turn there is a little swich that will prevent the dryer from starting if not made. just pull the idler tight see if switch clicks. other than that all the other parts you can check for continuity to see if good.
Aug 01, 2010 | Fisher and Paykel DG08 Electric Dryer
Kenmore 90 Series Model 11060912990 Dryer won't start
check motor (you have 2.4 Kohm ) very high read
for motor must be lower.Check capacitor if hawe.
Feb 15, 2009 | Kenmore 62602 Electric Dryer
Dryer
the switch on some models engages a small hold up relay could be a bad relay or loose wire to relay , worth a look
Jun 24, 2008 | GE DCSR483EA Electric Dryer
Faulty Start Button?
If the dryer doesn't even start to turn when you press the start button, then you have to look at a couple things; The start button itself, the starting relay or the safety circuit. You mentioned that there's a ticking sound... if this sound goes away when you open the dryer door but comes back again when the door is closed, then the safety circuit is working.
It could be the switch itself or the starting relay (if equipped with one). If you're mechanically capable, consider looking at the relay. See if the contacts are being pulled in when the start switch is pressed (DANGER: HIGH VOLTAGE). If it is, the start switch is OK.
Hope this helps.
Apr 02, 2008 | Dryers
Kenmore Electric Dryer Will not Run
there is a centrifugal switch on the dryer motor. pressing start energizes the start winding and the motor runs. when the motor is up to proper rpm the start switch is supposed to kick out and the motor runs on its run winding.
Sep 21, 2007 | Dryers
Dryers Logo
Top Dryers Experts
Marvin
Marvin
Michael Thomas
Michael Thomas
