Question about Homelite 'Yard Broom' Leaf Blower
Homelite bandit bx 90, What is the fuel mixture?? Thanks
Posted by lhaughton195 on
Ralph
  • 130 Answers
On the bandit, you are safe with a 40:1 ratio. In other words 8oz. of oil to 2.5 gallons of fuel.
Posted on Feb 12, 2011
What is the fuel ratio for a homelite LX30 chainsaw,ive been told 30/1 50/1 25/1 40/1. Which is correct thanks.
Find an oil you like and mix it according to the oil recommendations.
I use Opti-2 in all my 2cycle fuel mix and it's a 100:1.
What the oil manufacturer says to mix the oil/fuel is what you go by, not what the engine manufacturer says.
Opti 2 2 Cycle Oil 34oz EZ Measure Bottle 20112 eBay
Mar 05, 2018 | Homelite Garden
On the homelite DM 50 model 05020 what is the fuel mixture ratio?
What Fuel Mixture Do I Use for a Homelite Chainsaw Model ...
homeguides.sfgate.com > Foreclosures > Avoid Foreclosure
It has a two-stroke engine similar to newer models made by Homelite. The recommended fuel mixture is a 50-to-1 ratio of unleaded gasoline and two-cycle ...
Oct 25, 2015 | Homelite Garden
Correct fuel mixture for homelite zip start weedeater.25cc,ut20785..
50:1 five liters unleaded petrol and 100ml 2 stroke oil
Sep 09, 2014 | Homelite Garden
Is a gas and oil mix required for homelite bandit chain saw 33 cc. if so how much. just got it from a pawn shop
Yes! Normally 32:1 gas oil mixture is what you will need. The easiest way is to buy the oil in pre-measured bottles (Usually available in 6 packs). That way all you have to do is add one bottle per one gallon of gas.
Hope this helps.
(Don't forget bar oil)
May 02, 2011 | Homelite Garden
We have a Homelite Leaf Blower HB-180V Please adfvise the correct gas mixture for this product. Thanks. Bonnie Frommeyer
This appears to be an older model, which means more oil was allowed to be mixed with the fuel and the carburetors were tuned accordingly. The EPA has changed all that now. Your mix ratio is listed at 32:1. See the simple chart.
http://support.mtdproducts.com/app/answers/detail/a_id/347/~/two-cycle-engine-fuel%3Aoil-mixture-chart
Jan 11, 2011 | Homelite Garden
I just bought a used bx-90 bandit and it runs great. The problem is that fuel oozes up thruthe top of the fuel tank right where the fuel line goes in. It runs down the side of the tank and all over...
Just replace the fuel lines they become hard and shrink allowing leakage. If your tank is like upper the part number is HM-0745499 or like lower part number HM-UP03825 or you can take to local small engine dealer and he will probably change cheaper than you can buy.
Nov 09, 2017 | Homelite 'Yard Broom' Leaf Blower
Restringing a homelite bandit trimmer
What is the correct size of the nylon cutting material - on my homelite bandit SX-135 trimmer ?
Thanks, Bill.
Apr 30, 2010 | Homelite Consumer Products 4.0 Amp, 13 In....
I need to no what oil/fuel mixture the homelite backpack blowers use
It should have the mixture on a lable near the fuel filler cap; something like 40:1, or 50:1.Home Depot sells small bottles of 2-cycle oil for homelite engines. Mix one to a 1-gal of gasoline.
Mar 06, 2010 | Homelite Garden
BX 90 homelite leaf blower two idle screws
The initial setting is 1 1/2 turns out. Screw them all the way in and them turn them 1 1/2 turns out. This is the starting position and should start, it may need some final adjustments to run like you need it to run.
Remember more the screw is out the more fuel it will get.
Good Day.
Oct 14, 2009 | Homelite 'Yard Broom' Leaf Blower
Homelite 'Yard Broom' Leaf Blower Logo
Top Homelite Garden Experts
bryan st
Jay Finke
Jay Finke
colesmowers
Are you a Homelite Garden Expert? Answer questions, earn points and help others
