Homelite Mighty Lite Lawn Trimmer  Logo
Posted on Feb 12, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Homelite Mighty Lite has developed perished fuel lines. (12 months after purchase!!!!!!) Is it possible to obtain spare fuel line.... preferably attached to a new fuel tank as well. It looks like a really hard task to change only the lines. Many thanks. John
Anonymous
Level 2:
  • Expert 130 Answers
  • Posted on Feb 12, 2011
Anonymous
Expert
Level 2:
Answers
130
Questions
0
Helped
73114
Points
397
The fuel lines can be purchased separately usually by the foot from any outdoor power equipment dealer. They can be easily installed by cutting one end at an angle and "feeding" it through holes. Homelite fuel lines are of a different OD than most so make sure you get the proper size. The most popular size for Homelite is OD .203 ID .04.
How do the fuel lines hook up
I made a video of changing the fuel lines on my Homelite 25cc. Homelite Tune Up
Primer bulb not filling
Bulb or fuel line could have a crack or a clog in fuel line/filter or carburetor. Here's a video on how to change the bulb and fuel lines and another video on how to clean/rebuild the carburetor.
Homelite Tune Up
Homelite weed eater gas trimmer will not run how to rebuild weedeater...
2answers
Primer does not work
Homelite Tune Up
Bulb will not prime
Homelite Tune Up
1helpful
Homelite mighty lite 26bv gas Blower won't run full speed or only in Full Choke
Sounds like a lean condition. Rebuild carb, replace fuel lines and fuel filter and you should be ready to blow the leaves.
I need a gas tank for homelite mighty lite 26ss. the whole is too big in the gas tank for the gas line.
No, what you really need is the "correct" sized fuel line. Do not alter the hole in any way. Here is an offering for a complete fuel line replacement "kit". I think it is Amazon.com. The sizes of line they have should fit your make and model. See the third Item listed under BLOWERS at the top of the page. Click on that and you will see the item you actually need. Reasonable price too.
http://www.homeliteblowerparts.net/#2
Trimmers: Homelite Easy Reach-25cc-Model # UT20044B& Homelite Mighty Lite- 26cc- Model # UT21546 Both trimmers will start but when throttling up they cut out. They will also cut out when the choke is...
sounds like an air/ fuel mixture/ratio problem.there should be two screws side by side near the carb. crank trimmer and slowly adjust screws, in or out, till engine runs smoothly..
3helpful
2answers
Hello i have a question on changing th fuel
how to change fuel filter in gas tank remove line from carb pull line through the fill hole in gas tank remove filter replace & pull hose back up reconnect to carb & your done
Cracked fuel line
you can get many sizes of hose at the home depot
Top Homelite Garden Experts
Jay Finke
Jay Finke
Thomas Perkins
Thomas Perkins
Sean Wright
Sean Wright
Are you a Homelite Garden Expert? Answer questions, earn points and help others
