Question about Toys
Missing the screw insert pieces (wrong pieces that go into the wholes for the screws to catch on) for our Jardine Toddler Bed Model number 2110C00 dated 03-2007. Is this something we could order? Thank you, Sherrie Carey
Posted by kevin_sherri on
5 Related Answers
mcdevito75
Michael C. De Vito
  • 1970 Answers
SOURCE: LOST TODDLER BED INSTRUCTIONS
mcdevito75 here, You can try online at Disney Beds.com for info.
Posted on Jun 24, 2010
Anonymous
SOURCE: Jardine Crib 4 in 1
step 1: detach the front panel (part j) from the front posts h(1) and h(2) using allen wrench
Step 2 if mattress support (part K) is not in the lowest position, unscrew mattress support bolts (Part d) from the post and move it to the lowest position
Step 3: Using the wrench provided, attach the guard rail (part f) using 4 bolts (part a) between the left and right front posts
Step 4: tighten all screws clockwise.
good luck
Posted on Oct 24, 2008
Anonymous
SOURCE: Jardine Model # DA715BC toddler bed assembly
I have the same crib for my daughter when I went to change it I called the company bc I couldn't find the toddler rails that matched the crib.. They said that it doesn't convert into a toddler bed, just a day bed, and a full-sized bed.. I said NO it's a four in one.. their reply.." yes, a crib, a day bed, a full size bed with foot board, and a full sized without the foot board." I laughed and told them what a joke that was.. So my husband and I took the front off the bed to make it the daybed and went to walmart and bought a toddler bar for like 20 dollars in the baby department. She loves it and it worked for us without having to spend another 150 dollars for a cheap toddler bed.. good luck.. btw this crib has been recalled.. you might want to check it out
Posted on Mar 30, 2009
Anonymous
SOURCE: Need the insructions on how to turn crib into
I need the instructions on turning the Chelsea model #8324 into a toddler bed
Posted on May 03, 2009
I have a jardine toddler bed model TB14-N and have lost the hardware in a move. Any idea where to get replacement screws?
take a small part along to your hardware shop to get the right screws or find a cabinet hardware suppliers in your area and get any special screws from them
if you have a manufacturer name for the unit contact them on line for the screws
Apr 15, 2015 | Baby Gear
I lost the instruction Manuel and I need to convert the crib into the toddler bed
First I unbolted the four arms that hold the metal bed support up and pushed it down as flat as I could. I had to do it a couple of times and go kind of slow, to get the loose arms tucked away as best I could. They still stick up a little above the rest of the frame.
After much wrestling with the wooden front panel (gate) of the crib (the one I need to remove), here is what I did:
1. Find the wooden piece that crosses the bed just behind the gate. This is an approximately 1.5-inch by 3/4-inch piece. On ours, it's just above and in front of the drawer under the crib.
2. Find the metal screw at one end of this cross piece. You will see that it is on the outside of the bed, on the short end of the bed, in line with the cross piece.
3. Unscrew it. Note that this screw actually threads into a threaded piece inserted into the cross piece in a little hole on the back side of the cross piece, about 3/4 inch from the end. If this little silver metal piece falls out, you will need to find it and put it back in the hole with the threads facing the screw hole. The piece is the size of a pea.
4. Anyway, use an allen wrench to remove the screw, without losing that little inserted thingy.
5. I'm not saying this is textbook, but I then forced the end of the crib away from the rest of the crib while moving the gate up and down and pulling gently toward me (to pull the gate from its track). You have to move the end of the crib to create about a 1/2-inch gap before the gate will pop free.
6. The gate has two pins on each side, so when you get it freed on the site that you removed the screw on, the other side will come off without removing the second screw on that side.
7. I then got the drawer back on its tracks properly (it jumped the tracks a bit in the process), pushed everything back together the way it was, and screwed the screw back in. (if the screw wont thread, either you lost the aforementioned little silver piece, or that little silver piece is turned in the hold the wrong way)
8. With the gate removed, the crib (now toddler bed I guess) has four little tabs where the gate was once attached. Two I had to unscrew, and the other two I grabbed with a pliers and pulled out.
It wasn't elegant, but I certainly have an intact toddler bed now.
Hope helps. Good luck.
Oct 04, 2010 | Toys
I need to convert jardine crib to a toddler bed. I lost the manuel model number dase5508crp1.
Sorry this isn't a solution but I was wondering if anyone of you has the instruction manual if you could post the part that list the screws needed I lost mine and need replacements.
Sep 02, 2010 | Baby Gear
Jardine TB-08N toddler bed, need parts
I am in a similar situation and found a phone # for the company. I had to call and leave a message, but it's a start! 800-295-1980
Jul 31, 2009 | Baby Gear
Need to know how to convert from crib to toddler bed
Unfortunately Products America does not provide parts to the Jardine cribs due to a recent recall they underwent that covered a large quantity of their cribs. I did check your model number and it IS on the recall list as one of the cribs that has been determined unsafe. You may want to check on that before continuing use of the crib, even in toddler bed form it may be unsafe. Here is the link to the Jardine recall page: http://www.jardinecribrecall.com/
I have a toddler bed by Jardine Enterprises. Model TB-08W. I need to find replacement screws and don't know where to look.
I just got a phone number for Jardine Enterprises 1-800-295-1980. Because that model is discontinued (I have the exact same bed and same problem) they will send you a list of the parts that are needed and you can go to a local hardware store and purchase the pieces. Hope that helps
Mar 19, 2009 | Baby Gear
Jardine Crib 4 in 1
good luck
Sep 23, 2008 | Delta Luv Delta - Baby Products 5-in-1...
Jardine convertible crib instructions
Hi, I know it looks hard but It's really simple .just take out the screws that are on each side on the bottom and top 1 on the top and one on the bottom each side( 4 in total )(Sides not on the front) and that's it, the front part comes off and you save it for when you make the bed a full size bed wich that part becomes the foot board. Hope this information helps! Good luck!!
Jun 11, 2008 | Baby Gear
Toys Logo
Top Toys Experts
Tom Chichester
ray gallant
ADMIN Canada
ADMIN Canada
Are you a Toy Expert? Answer questions, earn points and help others
