Question about Hyundai Electronics Hyundai U90P 19" LCD Monitor
My eyes get strained with only minutes after looking at the lcd
Posted by limee1234 on
Kyle
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 4 Answers
To avoid eye strain you need to follow few tips, mentioned in this article:
http://place-4-papers.com/how-students-and-office-workers-can-reduce-eye-strain
Posted on Jun 05, 2018
Robin
    New Friend:
  • 3 Answers
Do you ever use any other displays (like a shared terminal at school or a library, or at work?), and if so do you have the same issue there? If you use both the LCD and the 13", try JUST using the LCD for a short time and see if your eyes can adjust.
Posted on Dec 18, 2011
Tip
Plasma TV viewing tip
When watching a plasma TV make sure that your room lighting is with in 1/3 of the distance between the TV panel and your seating position ( when measured from the screen end ). In other words, if the TV is off you should not be able to see the light source on the blank screen from your seating position. This method can reduce a lot of eye strain while viewing .
on Mar 07, 2011 | LG 42LC2D 42 in. LCD HDTV
One image is slightly above the other at all distances. After using the binoculars for even a couple of moments, my eyes are strained. The problem was present when the binoculars were purchased, however...
The oculars are not aligned properly causing double vision. Check on the binoculars to see if there is a place to adjust the alignment of either of the oculars. Look for any loose screws that may cause the two oculars to be out of alignment.
If this is not the case try adding some torque to the binoculars to see if the will adjust to where they will both point in the same direction. The eyes can fuse disparate images slightly but there is a very small range that they can handle. If the two images are separated by more than this small amount it will cause eye strain and double vision.
Feb 13, 2011 | Minolta 10x25 Activa D WP XL Pocket...
My Lenovo y510 display is blurry. Sometimes it
Need a replacement soon.
If you want a temporary solution for your eyes, use a regular monitor, and plug it to the laptop
Don't forget to rate if this answer helps
Jul 20, 2009 | Lenovo IdeaPad Y510 Notebook
Projector problem
if it's an lcd, the fly-eye lens might be burnt. return it.
Nov 29, 2008 | Office Equipment & Supplies
Dual Monitor Color/Brightness Differences
Correct the resoulution is not the same. Also you are using 2 monitors and using the system to power these great displays. Just dont hook up a docking station. The picture gets really bad..
Feb 13, 2008 | Computers & Internet
Eye strain (using LCD monitor)
====================== If you are having trouble with Newly bought items save your self from headaches by returning them and demand a replacement or a refund! You may have purchased a reconditioned\repaired\factory defect product.
Sep 16, 2007 | Computers & Internet
Hyundai Electronics Hyundai U90P 19" LCD Monitor Logo
47 people viewed this question
Top Hyundai Electronics Computers & Internet Experts
Ekse
Marvin
Marvin
Are you a Hyundai Electronics Computer and Internet Expert? Answer questions, earn points and help others
