Question about Pari TREK S Compact Nebulizer System ()
Green and yellow lights flash on battery while charging
Posted by kdxsteve on
Tonyb
    New Friend:
If all the lights are flashing, it normally indicated dead batteries as instructions say and I found out. Pari would have you buy a new power pack or likely high repair price to replace 2 LI-ION cells . But, unless you are very handy with electonic items, you may have no choice. We bought a 2nd unit originally and when those batteries prematurely died, I reserched and installed my own.
Posted on Mar 27, 2013
Battery light flashing yellow then green
A flashing yellow light usually means a low battery. When the light turns green, the battery is fully charged. It is helpful to list brand and model number because flashing lights similar to beeps from a computer, are usually brand specific codes which can be looked up on a chart to interpret.
Aug 11, 2015 | Computers & Internet
Pronto M6 chair will not work. When the power switch is turned on, the LED light flash Red followed by three Green. I can't find what this error code meas.... Pls Help thanks Phil
Phil the red means battery is low and the green is a speed limit code because of the low battery if you have charged your batteries and you still get the red then you need to check the charger after charging all night does the yellow light on the charger turn green? if when you first plug in the charger if the red light is on and the other light is green then there is a problem with the wiring or connection to the batteries from the charger and you aren't charging the batteries. if when you plug the charger in and you get a red and yellow light then the charger is working but you don't ever ge a green light and the battery level gauge is still showing red then you need to replace the batteries Hope this helps
Apr 12, 2011 | Invacare Supply Group Pronto M61 Standard...
Yellow and green light are on but wont charge battery?
If both lights are on and both are flashing the charger is reading the battery as defective and the charger won't charge the battery. If the Red light (yellow if plastic is faded) is on and the green is flashing the charger is trying to charge the battery. If the battery won't charge replace it.
Dec 21, 2010 | Ryobi Multi-Volt Battery Charger
My glowbouy flashes green and red...what does this mean
According to the owners manual for these swimming pool lights, this is what each colored indicator means. Hope this helps.
Solid green
The battery pack is fully charged.
Slow flashing green
The battery pack is almost fully charged.
Slow flashing yellow
The battery pack is half charged.
Medium flashing yellow
The battery pack is less than half charged.
Fast flashing yellow
The battery pack has almost no charge.
Fast flashing red
A charging error has occurred and the light should be unplugged and then plugged back in. If the Fast Flashing Red persists after several attempts, the battery condition is questionable.
Also in the trouble shooting guide, it mentions this:
Problem: Red Indicator Light Is Flashing While Charging
Solution:
A red flashing indicator light when charging indicates a selftest
error condition. Unplug the product and plug it in again.
Try this several times; if the indicator light continues to flash
red, unplug the GlowBuoy and take it to an authorized service
depot.
Oct 22, 2009 | NRS CANTAR GLOW BUOY FLOATING POOL LIGHT...
Dell 9400 wont show AC power icon
If the computer is connected to an electrical outlet, the about10.jpg light operates as follows:
  • Solid green: The battery is charging.
  • Flashing green: The battery is almost fully charged.
If the computer is running on a battery, the about41.jpg light operates as follows:
  • Off: The battery is adequately charged (or the computer is turned off).
  • Flashing orange: The battery charge is low.
  • Solid orange: The battery charge is critically low.
Looks like the AC adaptor is faulty.
Aug 25, 2009 | Dell Inspiron 9400 Notebook
Will not turn on after charging
Sounds like it's time for new batteries.
Jul 18, 2009 | Jet 3 Ultra Power Chair
Which indicator light on my mobil line battery charge complete
the green light should remain on when fully charged.
Regards
GeWiz.
Jan 11, 2009 | RTO Mobil Line Mobility Scooter Chair...
No 'green' light on bacl of my 'old' Vivitar 285
Then I'd say it's a reasonably sure thing that the green light is just burned out, The lights are supposed to be off at first, then red when there's a partial charge, then green when there's a full charge, then flashing between red and green when the "battery saver" kicks in. If you're seeing off, then red, then off, then flashing red, then that means everything in the charging circuit is working perfectly, there's just no green light.
Nov 30, 2007 | Vivitar 285HV Flash
Pari TREK S Compact Nebulizer System () Logo
Top Pari Health & Beauty Experts
ray gallant
ADMIN Canada
ADMIN Canada
Bill Boyd
Are you a Pari Health and Beauty Expert? Answer questions, earn points and help others
