Question about Kodak C195 Digital Camera
When i connect the camera to the computer and turn the camera on it immediatly turns itself back off
Posted by greggtaylor3 on
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Kodak Master
  • 102,366 Answers
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
Posted on Jun 07, 2011
Camera will turn on and after only a picture or turn will turn itself off. (The lens moves back in). I have replaced batteries but this doesn't fix the problem.
this is not a problem , it means your camera is closing its lenses immediatly after some idle time.
just go through the manual and change the idle time by some margin as per your needs.
your camera is working perfect
Dec 29, 2009 | Kodak EasyShare C360 Digital Camera
My EOS 400 turned itself off and now wont come back on. Tried batteries and memory card but nothing
Is the camera recognised in windows when connected via USB to a computer. (Camera power switch in the on position)
Aug 20, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
Camera immediatly shuts off and lense goes back in.
Sounds to me that ist is more of a charger issue. Try to borrow another charger and see if that works or not.
Jun 11, 2009 | Kodak EASYSHARE M1063 Digital Camera
CANON IXUS 75 Cannot upload photos to pc anymore!
OK, I'VE GOT ONE IDEA THAT MIGHT WORK. IT'S WORTH A TRY. DO THIS. TURN YOUR COMPUTER OFF> CONNECT YOUR CAMERA>TURN THE CAMERA ON>THEN, TURN YOUR COMPUTER ON AND SEE IF YOUR COMPUTER WILL RECOGNIZE IT THEN. THIS SHOULD CAUSE THE COMPUTER TO RECOGNIZE THE CAMERA. GOOD LUCK AND I HOPE THIS WORKS! IF YOU NEED MORE HELP,REPLY TO ARCLIGHT1217.
Oct 14, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
TV turns off by itself
you have a bad CRT causing the set to shut down. after the CRT has cooled down the computer finds all value to be ok then comes back on....
Jan 07, 2008 | Philips Magnavox 24MC4306 24" TV/VCR/DVD
Image blacked out on LCD and can not see image in view finder
Try connecting it to a computer and then turning on the camera. For some reason that fixed it for mine.
Nov 24, 2007 | Canon PowerShot SD10 / IXUS I Digital...
Can't turn on Vivitar 4345 digital camera
Searching google groups shows others with problems after attaching Vivitar cameras to PC's & then not working. The only fix seems to be leaving the battery out until the camera resets itself. If you can get to the setup menu then try the "default" option to reset the camera to factory settings.
Jul 22, 2007 | Vivitar ViviCam 4345 Digital Camera
Camera turns on then off
What will $135 plus a bit buy in the way of a new camera? This is a firmware problem- really Kodaks problem they should offer you a replacement camera for a little less than $135. Push them hard.
Jul 12, 2007 | Kodak EasyShare Z740 Digital Camera
FinePix 1400 won't turn on, it beeps and shuts off immediatly
Toast it seems to be but give a look into Fuji tech support team
May 31, 2007 | Fuji FinePix 1400 Zoom Digital Camera
Aiwa F2400 TV turns off itself immediatly after turned on
The safety circuit in the tv is sensing something is wrong and that is why it turn the tv off,it might be a regulator giving you more voltage that what he is supposed to give you.It should be a simple and inexpensive repair,get a qualified person to give you an estimate.
Sep 15, 2006 | Aiwa F2400 24" TV
Kodak C195 Digital Camera Logo
Top Kodak Cameras Experts
Steven Wander
Steven Wander
Are you a Kodak Camera Expert? Answer questions, earn points and help others
