Question about Jaeger-lecoultre JaegerLeCoultre Master Reveil Q1412420 Wrist Watch for Men
I have jlc movement 450 with dial but case is missing
rpugh77
    New Friend:
    Problem Solver:
  • 8 Answers
Cousinsuk.com choose branded watch parts, select the brand and search. They are in England but I use them all the time, you have to go through there little signup procedure but whatever it takes, right?
Posted on Feb 13, 2011
Where can i find watch dial for shc041
Firstly, what is a shc041? The cleats are called dial feet. They orient the dial to the movement so 12 is always at the top. When they break the dial spins around. Three solutions. Anew dial from the manufacture. A used dial from another watch, maybe from a popular auction site, or "dial dots". Small adhesive dots used to adhere dials with broken dial feet to movements. Sometimes successful, sometimes not. A forthis to send the dial to a dial refinishing company and have new feet soldered on.
Oct 19, 2011 | Seiko SHC041 Watch
How do i remove crown?
hummmmmmm
u need to go experts of watch reper i think its its problem in watch curcuit thats y this happen
& thnx useing fixya
Mar 28, 2008 | Tag Heuer Formula 1 CAC1111.BA0850 Wrist...
I went to put a new battery in a LACOSTE model or part number 2000308 ladies leather strap watch only to find that there was no movement at all ???? what movement and spacer if any do I need
A watch with no movement in it is probably a salesman's sample or display model. These are often distributed to stores as part of a larger display. In addition to missing a movement, you should also check to see whether the hands have been glued in place. This is also often done because, without a movement, the hands would just flop around instead of staying in an attractive position.
Watch movements come in a variety of standard sizes and shapes. However, a standard ladies watch movement (made by many manufacturers) would probably fit your watch case. This size movement is today used in much larger watches, too; the movement is simply anchored by an appropriate spacer.
A jeweler advertising watch repair should be able to offer you a price on this job. If the hands have been glued to the dial, it may not be worth "upgrading" the watch because of the additional expense and potential damage to the watch face from getting the hands freed up.
If you're ambitious and want to try it yourself, movements can be found online at a variety of watch supply houses like Otto Frei. You can also buy a cheap new or used watch at a flea market or thrift store and use the movement from that. You might be able to re-purpose the spacer in that watch, too, by trimming it to fit your watch case. The major stumbling point here is that watch stems--i.e., the stem on which the setting crown is located--are usually custom-cut in length to match a specific case, and the one you select may be too long or too short for your case. A watch repair place should be able to replace the stem and crown for you, if you need that service. Trimming an overly-long stem is a very simple and cheap procedure; replacing the stem requires a new stem, which will add to the cost of the repair.
May 09, 2011 | Lacoste 2000308 Watches Watch for Women
My white dial Cartier tank (15 years old) is chipped, the white chipped paint is all over the inside of the watch. I cleaned it today at the watch maker but the dial is ugly. I called Cartier and they...
There is nowhere to get a Cartier dial from, other than Cartier.
Options:
1 - Pay the $400 for the genuine dial.
2 - Buy a 2nd hand watch off eBay to use for spare parts.
3 - Have your dial repainted.
Dial repaints can be a bit hit and miss with quality though. Talk to the watchmaker and ask who they use to do it. Should be 1/2 the price of a new dial.
Aug 21, 2017 | Cartier Tank Francaise Chronograph White...
I have a diesel watch model dz-2136 I need to know how to remove stem
Thank you for contacting FixYa.
I dont know why you want to remove the stem but here you go.
To remove the stem you must first loosen the set lever screw, then you can pull the stem out.
You only need to turn the set lever screw a couple turns to release the stem. Some movements use a button instead and in that case you would simply push the button down lightly with a pointed tool and while holding the button down pull the stem out.
For watches with one-piece cases where the movement comes out the dial side and the case has no removable back, you will not be able to get at the set lever screw. For this type of watch you must grasp the crown firmly and pull it out, or use plastic or soft brass tweezers to get behind the crown and pop it off. These watches have two-piece stems that have male and female ends that snap together. Then remove the bezel and let the movement come out into your hands. Then remove the hands and the dial and put the movement face down into a movement holder. Now you can remove the stem as described above
Aug 26, 2010 | Diesel Audio Diesel Watch
How do I remove the crown/stem to take the watch movement out of the case? thanks Marc
Apr 04, 2010 | Watches
Where can I find a circuit board for JLC reverso quartz movement
This is very, very complicated. If FixYa will allow - you have to contact me directly. My email: [email protected] I don't know how you can do that, but think its possible (direct contctwise).
Feb 04, 2010 | Watches
How to replace crown to Raymond weil 9124-2
If i were you , i'd contact directly the brand on their Official Website. This is best done by watchmaking specialists :
RAYMOND WEIL Swiss Watches
Mar 12, 2009 | Raymond Weil Automatic Watch
DIFERENT DISPLAY FOR THE SAME WATCH MODEL.
A watch is considered Swiss, when it is made in Switzerland (hope I spelled that right), by a Swiss Comapny, using 50% or more parts that are also Swiss. Watches made this way will have "Swiss Made" Swiss" or a similar print on the back.
If it has the lables of "Swiss movement" "Swiss Case" then it means that it is only partly swiss made, and will not have a lable listed in the first part of this solution branded on the back.
Hope I helped, have a great day.
Jan 13, 2009 | Invicta Swiss Pro Diver 9309 Wrist Watch
SECTOR 450 TIME ABJUST
when looking at the face of the watch, the "dial" to the bottom-right is actually a screw-in, screw-out dial, it is not a push dial. Unscrew it until it is freed from the screw AND THEN pull it out two clicks, adjust time as needed...
Apr 21, 2008 | Sector 450 2653450035 Wrist Watch
Jaeger-lecoultre JaegerLeCoultre Master Reveil Q1412420 Wrist Watch for Men Logo
74 people viewed this question
Top Jaeger-lecoultre Watches Experts
Janelle Schoonover
Janelle Schoonover
Marvin
Marvin
Are you a Jaeger-lecoultre Watch Expert? Answer questions, earn points and help others
