Question about Dell Dimension 4600 PC Desktop
I have a dell dimension 4600. I had to install windows xp again and now my drivers are gone. I have no cd's for installing the drivers again. Can i have a link to the right drivers i need?
Posted by germie00 on
Anonymous
    Brigadier General:
  • 8,909 Answers
~To download drivers and specific software;
Always get your drivers from the manufacturer of your Laptop, Notebook or Desktop.
If you were to log on to the dell.com web site, usually one is able to download if available, by model number, All available Driver downloads as required.
If the driver is not available, perhaps your manufacturer does not support the OS you are installing.
This is the best way of ensuring up to date drivers for your system and they are free of charge!
There are no XP drivers to be found with Microsoft as XP is no longer supported.
Some manufacturers may have a limited number of Drivers still listed.
I hope this helps.
Posted on Feb 12, 2011
Dell dimension 4600 setup
http://www.dell.com/support/drivers/us/en/04/Product/dimension-4600
DRIVERS.
ABOUT Os THAT CAN YOU PURCHASE AT ANY PC-DEALER.
JUST PUT THE DVD IN YOUR CD/DVD-PLAYER 32X OR 64X DVD FOR THE PROCESSOR YOU HAVE.LET WINDOWS DO THE REST
Jun 23, 2013 | Computers & Internet
Dell dimension 3000 series won,t install drivers and utilities cd after fresh install of windows xp sp2
Hello
Run the windows update again to win sp3.
Sp3 has most of the drivers in the dowload.IF not you should be able to install utilities after you get win xp sp3
Apr 12, 2010 | Dell Dimension 3000 PC Desktop
I have a Dell Dimension 4600. I need to re-install Windows XP Professional. The PC won't boot from the CD-ROM. When I choose F12, then Boot from IDE CD-ROM, the PC boots directly to Windows. how can I get...
Check the BIOS to make sure that the CD rom is the first boot devices in the bootup sequence, also make sure that the cd rom does show up in the BIOS.
Make sure that the CD Rom itself is good or the boot cd you are using is good, try it on other PC.
Oct 29, 2009 | Dell Dimension 4600 PC Desktop
Dell Dimension 4600 stalls during boot
Turn the computer's power on.
Immediately put the original Windows XP CD into the drive.
Tell the computer to boot from the CD (not from the hard-drive).
Does it start to boot from the CD?
Do you get as far as the "repair/install" boot-screen?
If so, your basic hardware is OK, and turn your computer off,
rather than choosing "repair" or "install".
Then, it's probably either the hard-drive that is failing,
or the installed copy of Windows XP is fuddle-duddle-ucked up, so that it cannot finish the "Windows startup" processing.
Apr 23, 2009 | Dell Dimension 4600 PC Desktop
Deleted browser driver for dell dem. 4600 desk to windows xp home
Assuming that you deleted the ethernet driver.
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=DIM_P4_4600&os=WW1&osl=en&catid=&impid
if you placed any other modem in the system, then tell the modem name. or else it is an onboard ethernet. you can driver from the above location
Apr 21, 2009 | Dell Dimension 4600 PC Desktop
PC will not boot from CD drive
Download the six winxp install floppies,,from bootdisk.com and install that way.
Your PC was not meant for XP it was meant for Millenium at most.
But if you load through floppies and then use the cd you should be OK
Jan 19, 2009 | Dell Dimension 4600 PC Desktop
Network Card Driver Windows 2003 Dell Dimension 4600
http://support.dell.com/support/downloads/download.aspx?c=us&l=en&s=gen&releaseid=R67150&SystemID=DIM_P4_4600&servicetag=&os=WW1&osl=en&deviceid=2834&devlib=0&typecnt=0&vercnt=2&catid=-1&impid=-1&formatcnt=1&libid=5&fileid=87106
Try this driver
God Bless Greg
Nov 20, 2008 | Dell Dimension 4600 PC Desktop
Can't reboot windows cd on with cd drives
If you have it available, boot to the Dell DImension Resource CD and run the diagnostics on the hard drive. From the description of you problem, you may have a failing hard drive.
Other things to check:
1. Ensure the system BIOS (F2 at boot) sees the hard drive and has the correct date and time. If the motherboard battery is failing, the time and date will not be retained when system is powered off.
2. If you are able to format the hard drive, but the windows XP installation process gives you file copy errors, then you may have a bad RAM module. If the system has 2 or more modules, take out all but 1, retry the install. If you get file copy errors again, try a different module.
3. If the Hard drive passes dieagnostics, but fails to complete a format, replace the hard drive.
Jun 01, 2008 | Dell Dimension 4600 PC Desktop
Ethernet controller driver
i need an ethernet controller driver for my dell dimension 4600 the operating system is windows xp home edition
Sep 02, 2007 | Dell Dimension 4600 PC Desktop
Dell Dimension 4600 PC Desktop Logo
efs_perpends
efs_perpends
Michael Thomas
Michael Thomas
