On booting up the laptop the screen goes white
Posted by acoz57 on
Brian Sullivan
  • Computers & ... Master
  • 27,725 Answers
During the boot process you will see on the screen to press delete to enter setup
Press and hold delete during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart then
once you have your computer running try
click start control panel administrive tools computer management device manager scoll to ports(com&lpt)right click to scan for hardware changes or scroll to monitors + to expand plug and play monitor right click where you have options to update driver,disable.uninstall,scan for hardware changes or select properties where in the general you have the option to troubleshoot also in the driver tab you have the same options as when you first right click on monitor
also
click start control panel,display,desktop you can select a different desktop from the drop down list also settings you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general dpi normal size,larger size or custom settings
always click APPLY after making any changes
if these fail to fix the problem you will need to check the ribbon/lead that is attached to the monitor make sure the connection is good and the ribbon/lead is not faulty or replace it
if still no fix you might need a new monitor
hope this helps
don
Posted on Feb 12, 2011
My Acer aspire 5315 laptop,screen/display has gone all white.Please what should i do about it?.
if possible plug in to a external monitor if the display on the ext. monitor is white is likely video chip on motherboard. if its white the second you turn it on try the above. found here
white blank screen on acer aspire 5315 laptop how can fix this
if you see boot a little then it goes white watch this video
Laptop white screen trojan virus infection easy fix
Jul 03, 2015 | Acer Computers & Internet
I have a dell vostro 1720, while booting up, you can see the home screen for about 2 seconds, then goes white screen and you can't see anything. tryed starting in safe mode, and got the same thing
This could be a virus.
The quickest way to fix this problem is to use your Dell recovery CD.
Boot up with this recovery CD follow the instructions and it will restore your Dell laptop. You will lose your data and you will need to install your programs again.
Mar 25, 2013 | Dell Vostro 1720 (bqcwd1z) PC Notebook
Mac air white screen won,t boot
try resetting your hard drive. your screen might be going.
Mar 13, 2013 | Computers & Internet
My laptop Preasario cq61 has the black screen problem, when it starts it shows the first screen fine ( the one where you can hit ESC to enter the bios) after that it goes black and in the top left corner...
http://h10032.www1.hp.com/ctg/Manual/c01141784.pdf
OK download that service manual, follow the troubleshooting procedures and you will sort your problem out in now time, i have a hunch, that your HDD, is faulty... and may need replacement. Anyway Download and use that manual, it's a generic one.. but will still work for you.
Apr 11, 2010 | Compaq Presario Notebook
My laptop is compal n30n3 when i start my laptop its screen gets white and remains white
Try booting up from a recovery boot up CD. This will test whether it is a hardware or software issue. If there's no white screen with the CD boot, then it could be a malware or some other driver/program corruption. If however, the white screen still shows up during a CD boot, then it could be an overheating issue due to a cooling fan blockage (the fan may not turn on at all). Or it could be the monitor itself in which case I'd suggest you try connecting the laptop to an external (LCD) monitor and see if the problem then persists. Hope it all goes well for you. If any of my suggestions work, please do rate me. Thanks
Feb 04, 2010 | Compal Computers & Internet
White screen after i get to desktop after login
Restart laptop, hit F8 Repeatedly, boot safe mode, then do a system restore as far back as possible, Post here again if that doesn't fix the solution.
Oct 22, 2009 | Dell Inspiron 1525 Laptop
Blank white screen in my Acer Travelmate 5730 Laptop
Hello Karthik,
This must surely be a problem with your monitor, because you say that you see the white screen while boot up. If this is a graphic driver issue, you may have the problem after booting up in windows. Since its been only a month old laptop, the product must be in warranty for sure. Take away any CDs in the drive, any USB drives and see if this white screen appears. Let us know.
Thank you!
Sabharish
Jun 26, 2009 | Acer LXA3706003 Notebook
Computers & Internet Logo
k24674
