Check the filter at the front of the machine at the base. There should be a small cover at front of machine at base. Open this cover and inside you will see a circular cap. This needs to be unscrewed anti clock wise, it can be stiff if not used before. remember you will have to catch the water that comes out and pull out any debris inside. It is possibly blocked or has debris inside. Remember you will have to catch the water be prepared. --- Please dont forget to vote if you liked my answer thanks ------
Hi, I'm not sure about siemens machines but normally the filter is on the front of the machine in the bottom right hand corner, it maybe behind a clip on panel the you have to pry off or fold down.
I can't look for a manual to be able to give you more information as you haven't provided the machines model number.
Hope this helps
