Question about Sony Ericsson Walkman W810i Cellular Phone
I entered a code and can't remember it - Sony Ericsson Walkman W810i Cellular Phone
Posted by kenroy samuel on
Muntejaya Ginting
  • 10,422 Answers
Please get it unlocked at www.unlock-zone.com
Posted on Feb 12, 2011
I can not get into my phone at all. it has on the screen enter backup pin and i dont know what it is
Usually if one has a pattern for a lock code and if one enters the wrong pattern too many times it will ask you for the back-up PIN which you should have entered as a back up means to get into the phone after choosing the pattern code. I guess you never wrote it down and forgot it????
If you can't remember either the pattern code or the back up PIN, you might be in trouble.
Since you should remember the pattern code after having entered it multiple times you might be able to get around the back-up PIN request by powering off the phone, then powering it on and being careful to enter the pattern code accurately. Usually, the failed pattern code input isn't remembered by the phone after a power off.
Mar 14, 2015 | Boost Mobile LG Realm No-Contract Cell...
I need my password reset
I don't remember password on the amazon fire I want to put on my vizio smart tv also have a promo code for it too
Dec 18, 2014 | Netflix
I change the security code on my nokia x3-2 touch mobile and i forgot to re-open again. how im going to recall and reset the password?
If you still got the hint code which you remember,try this method
1. turn off your mobile.
2. remove battery for at least a HOUR.
3. put it back again and turn it on
4. enter the HINT code you remember.
If you enter wrong code for several times,the security counter will be block need to reset.
While if you still enter wrong code,just bring it to a mobile service shop near you and they will read your code using a gsm gadget.
Hope this method helps...thank you for visiting fixya..
Jun 22, 2011 | Nokia X3 Cell Phone
What should i have to do for change security code?
Your Nokia phone was designed with a default security code of 12345.
To change it,
1. Go to 'settings' on your phone.
2. Then 'security'.
3. Then 'access codes'.
4. Then 'change security code'.
5. When you select to change security code,
it would prompt you to enter the security code (initial one, ie. 12345).
6.When you have entered the intial one, it would prompt for the new code.
7. Enter any 5- digtit new code of yours.
8. It would prompt for a confirmation.
9. Re enter the new code.
And your security code is changed. But remember to use number you can easily remember.
Hope that was helpful?
Regards.
May 20, 2011 | Nokia N73 Music Edition Smartphone
Keypad is locked
Blackberry has given the keypad unlock code for security purpose if you dont remember your keypad unlock code. You need to enter wrong password for 10 times you're handheld will get wiped out you will lose all the data which is there in you handset, Then it will ask for the Reset password enter the new password and remember that.
Aug 01, 2009 | RIM BlackBerry 8700c Cellular Phone
Plz help me
first enter ##3283# on the main screen as a phone number.
a scren will appear, scroll all the way down to Advanced.
then another screen will appear, go down to Lock Code and hit the enter button.
the current lock code will appear
remember it!
then go to settings/tools
go down to More...
then go down to Security and enter the code that u were to remember
then go to change lock code
thank u
rate me
Jul 22, 2009 | LG KG800 Cellular Phone
I have to enter my modem access code to connect to the internet after I shut down my pc or it is inactive for a while
Yes this is typical of any security code... it will remember it for a limited amount of time... the next time you enter the code there should be an option to remember the code and if you select this it will always be connected.
Jun 22, 2009 | AT&T High Speed DSL Modem
Sony E k550i
What kind of code is it asking for?
If it ask for a PIN code then it means it's asking for the password/code you have entered on your SIM card. If it asks for Security code then that means it's the password/code for the phone.
Entering three invalid PIN codes on your phone then your PIN may be locked and you can only unlcok it by entering the PUK code on your SIM. PUK code is available on the sim card pack. Once it's ented, you have the option of changing your PIN code. Just be sure to remember your PIN code so the same incident won't happen again. If it ask for security code, enter the code you have for the phone but if you don't remember setting a security code, then you may try the default security code of Sony Ericsson phones which is 00000.
May 05, 2008 | Sony Ericsson K550i Cellular Phone
Sony Ericsson Walkman W810i Cellular Phone Logo
Top Sony Ericsson Cell Phones Experts
aliasger yq
Resolution IT Dubai
Resolution IT Dubai
Jax Planet
Jax Planet
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
