Question about Gaggenau EB 270/271 Electric Single Oven
The electrical mains switch was turned off. When I turned the oven back from the mains , the oven turns on but does not generate heat. I think it is something small do with my settings. Can u help. Patricia
Posted by Ptsouros on
Barry Coates
  • Gaggenau Master
  • 3,463 Answers
If it has a timer, then when the power was on again, it probably reset to auto, you need to reset it to manual cooking
Refer to your instruction book if you have one.
Otherwise it is a question of pressing 2 or more buttons at the same time on the timer to reset it to manual
Posted on Feb 12, 2011
Cant get my elecric single oven mm55524 to turn back on tried fuse in plug thats ok plz help
You need to check the continuity of the wires from the mains plug to the main heating coil. This means that the switch and the circuit to the heating coils will confirm the short. If the heating element is short then the main line should be removed to confirm the short and so the circuit will not trip.
Aug 18, 2011 | Whirlpool GBS307PR Electric Single Oven
Main oven does not heat up
When you turn the main oven on, does the oven fan switch on?
When you turn the main oven on does the cooling fan come on?
Does the dial illuminate when the oven is turned on?
Does the oven thermostat neon come on the the oven is switched on?
Have you had a power failure recently and have not set the clock?
Are you sure that the clock/timer is NOT set and in manual mode?
Dec 13, 2009 | Stoves 720EF Electric Double Oven
Oven not heating
Hello.
If the fan is working, but there is no heat, then it is the fan oven element that needs to be replaced.
It has nothing to do with timer on this occasion.
Remove panel at rear of oven compartment, there you will see the round element.
Undo fixing screws,and remove element, disconnect leads and fit onto new element, refit new elemrnt, replace cover, and job done!!!
Please leave a fixya rating for my solution.
Thankyou
Feb 04, 2009 | Hotpoint DY46 Style Line Stainless Steel...
Top oven (and Grill) have stopped workingMy 3 Year old AEG Competence D2100-4 Double oven has malfunctioned.  Bottom (main oven) works fine but top oven and grill have ceased to function.  The fan will run...
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Nov 12, 2008 | AEG D2100-4 Electric Double Oven
AEG D2160 Double Oven - electrical fault
you may find that one arm of the oven selector switched has fused to its contact.
Sep 07, 2008 | Ovens
OVEN TURNS ON BUT WONT HEAT UP.
heatman101
Aug 25, 2008 | Whirlpool RBD305PD Electric Double Oven
Oven no heat
check fan element hasnt blown remove back plate in oven after switching off from mains of course and remove the retaining screws and you will see a fan and around that the element it will be obvious to see if its blown as there will be a hole on the casing if so replace and viola.
Jan 16, 2008 | Neff B1641 Single circotherm super...
AEG B2100 Not heating up - light does not turn on
Main selector switch may have burned contacts.
Nov 07, 2007 | AEG B2100-4 Electric Single Oven
Gaggenau EB 270/271 Electric Single Oven Logo
Top Gaggenau Ovens Experts
Dennis Boxerman
john h
Vernon Taylor
Are you a Gaggenau Oven Expert? Answer questions, earn points and help others
