Question about ViewSonic Office Equipment & Supplies
My viewsonic projector shows overheat after it's start. then go to sleep after 10 sec.
Posted by sreelaj on
Anonymous
    Brigadier General:
  • 8,909 Answers
Are the air filters clean? It may have a faulty temperature sensor or indeed the temperature sensor may be disconnected.
Posted on Feb 12, 2011
I got a viewsonic pjd5111 projector used . it power on for aleaast 30 sec and shut down immediately temp light red and lamp light green . i hv tried everything .help
Check if there is a cooling fan. Is it rotating?
It is also possible that the filter is dusty and needs to be cleaned/replaced.
(all projectors have a cooling fan and a filter to prevent dust from reaching the lamp. A faulty fan or a reduced air flow may cause an overheat problem)
Aug 16, 2016 | ViewSonic Office Equipment & Supplies
My ViewSonic PJD6221 Projector shows scattered white dots on the screen
Your dlp chip is going bad and cannot be fixed economically. Several of the mirrors on the chip are hanging up and they won't come back. It will just get worse. My Sharp XR32X is doing the same thing. New projector time.
Jul 07, 2012 | ViewSonic PJD6221 Projector
PJ658 lamp replaced - still not working
Hi, did you solve your problem? I've got exact same problem with it?
May 24, 2010 | ViewSonic Projector Lamp
Projector shuts down ca 20 sec from start.
sounds like you may have the wrong bulb and it is being overpowered.
Dec 15, 2009 | BenQ PE8720 DLP Projector
Dvd player to projector
Yes please.
You can connect it either thru the RCA Composite output(yellow) of your DVD or thru the S-Video or even thru the component out(YPbPR) connections. In the component out you would require three RCA cables and would give you the best possible picture.
Find a link below , which gives a review of the Viewsonic PJ 501.
http://reviews.cnet.com/home-theater-projectors/viewsonic-pj501/4505-7858_7-20722971.html
Hope this clarfies.
Please do rate this solution and thanks for using FixYa!
Mar 04, 2009 | ViewSonic PJ501 Multimedia Projector
Lamp timer reset on my veiwsonic pj503d
hold the up button ( on the actual projector not the remote ) for 5 sec and then press auto
Sep 07, 2008 | ViewSonic PJ551 Multimedia Projector
My ViewSonic PJ458D problem
This is known as 'cycling' and is common with mercury-vapor bulbs nearing end-of-life. When the bulb first starts, it glows dimly and grows in brillance. As the light grows, the pressure and temperature of the bulb also grows--increasing power demand. After a short while, the demand exceeds the ballast limit and the bulb extenguishes until the temperature (and pressure) drop again. Then, the cycle starts over. Bottom line: you need a new bulb (or, the correct bulb).
Nov 13, 2007 | ViewSonic PJ458D DLP Projector Multimedia...
VP920 goes to sleep
Running Vista? Seems to be a pretty common problem. Thought it was a driver issue at first, since one of the newest released drivers listed a similar issue.
Aug 11, 2007 | ViewSonic VP920b 19" LCD Monitor
Top ViewSonic Office Equipment & Supplies Experts
Michael Thomas
Michael Thomas
Lawrence Oravetz
Are you a ViewSonic Office Equipment and Supply Expert? Answer questions, earn points and help others
