Question about Tools & Hardware - Others
My paslode battery is fully charged but flashes red and does not fire gun.any ideas?
  • Anonymous Feb 12, 2011
    How do you know the battery is fully charged ?
    Charlie
David Ford
  • 2,176 Answers
Paslode troubleshooting indicates that the battery contacts might be corroded, try cleaning them first and also look at the contacts inside the tool for same condition, they also say it might be a bad battery. Do you have another one that you can try? Let me know if you need more help before voting please. Thanks
Posted on Feb 12, 2011
Testimonial: "thanks for your help.it was the contacts.problem solved."
  • David Ford
    David Ford Feb 13, 2011
    Charlie, the light on the charger goes from red to green. If you insert the battery and the charger flashes from red to green constantly it would indicate a bad battery, but before replacing clean the battery contacts with an eraser or similar to remove corrosion and retry.
  • Daniel Jones
    Daniel Jones Feb 16, 2018
    my battery fully charged it start red waited about an hour it went to green plugged it in gun but it is completly dead but my other battery works
Battry charged but red light on gun still flashes on im 250
The red light flashing on the gun means that the battery does not have enough voltage to operate the tool. Try another battery and if it still flashes red you need to replace the spark unit
Aug 25, 2012 | RTO Paslode 902000 IM250 Ii Cordless 16...
Paslode impulse framing nailer , iv cleaned gun and oiled , the fan works etc . seems to only fire if i have fully charged battery ,once used for about five minutes it stops firing . only way to get it...
When it stops firing is the little light on the side of the handle green or red? If it is red then the battery is draining down too quickly. Either the fan switch has malfunctioned causing the fan to run all the time (I have seen this before) or you got either a faulty battery or charger.
Mar 05, 2012 | RTO PasLode 900420 Impulse Framing Nailer
Paslode impulse finishing gun wont fire. battery fully charged and gas is full.
Here is a tip that I wrote about the Paslode nailers and the problems that can come up with them.
I also have a link to the Paslode manuals which contain Paslode cleaning and troubleshooting guides.
If you need parts for your Paslode, there also is a link for a site that sells the Paslode nailer parts.
Paslode Cordless Nailer Problems
heatman101
Jan 01, 2011 | Omega Paslode 901000 Impulse Cordless...
I have Paslode IM 250 A nail gun, the battery is fully charged and a half used gas cartridge but I can not get it to fire.
heatman101
Sep 15, 2010 | Craftsman Nailer Kit, Palm Air Driver
Gun will not fire, battery is charged & good ??? model #IM25011 part # 900400 Bob
problem solved - battery charger indicated that battery was charged with green light on, took battery ouit & placed it back in charger & red light came on after doing this three times the battery was fully charged and the gun worked fine.
thanksBob
Jan 29, 2010 | RTO PasLode 900420 Impulse Framing Nailer
Paslode nail gun 325 black not firing
Any time these guns become intermittent or stop firing but the fan still runs, the first the to check is the expiration date on the gas cartridges. The do expire and this will make the gun work inconsistently or not at all.
Dec 08, 2009 | RTO PasLode 900420 Impulse Framing Nailer
Shoot no shoot
make sure that the filter in the back is clean you can pop the back cover off and clean it with water if it is dirty then the excess co2 gas that the gun gives off will not be able to excape the chamber and sensors inside the gun will not let if fire. This should work for you
Sep 01, 2009 | RTO PasLode 900420 Impulse Framing Nailer
Paslode 1st fix gun .battery fully charged and placed into gun.the light flashes green and the gun will fire once after which the light flashes red and the gun will not fire.any ideas.i have tryed other...
I would look at the fuel cell on the bottom is a expiration date and they will not fire older fuel. Also do you remove the battery and it does the same thing? When you depress the safety on the work can you hear the fan motor? You say the tool is clean does it have enough lube to move all items freely. Just a couple thoughts, Also look at the spark plug wire for being broke or coming out of the spark unit. Let me know and we will go into this deeper.
Jun 30, 2009 | RTO PasLode 900420 Impulse Framing Nailer
Fan not working
If the battery is flashing red, the battery is not charged or on a minimal charge.
Have you attempted to recharge it and does it still give you this symptom?
K
Jun 21, 2009 | RTO Paslode 902000 IM250 Ii Cordless 16...
Tools & Hardware - Others Logo
Top Tools & Hardware - Others Experts
Bill Boyd
Tom Chichester
ray gallant
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
