Question about Westinghouse Refrigerators
We have a 2door fridge freezer, the freezer side is working fine , the fridge side is v poor, appears to be only cool air comming out of the middle vents, its been very hot whwre we are, is there a filter or anything we should clean. the fridge is about 3 yrs old. regards john
Posted by wanja52 on
Anonymous
    New Friend:
  • 93 Answers
John ok there is a knob with letters on it trying turning it to c . in essence what u r doing is opening a vent to allow cold air from the freeze into the ref. try different letters till u get one that u like.. ok
Posted on Feb 12, 2011
My fridge is not getting cold but the freezer is fine
unless you have a very high end appliance with dual controls and compressors , on most fridge's the regular item compartment is cooled by cool air from freezer , some middle models allow you to control the amount of cool air allowed into fridge compartment via a shutter between the two sides
Oct 28, 2015 | Refrigerators
Kenmore side by side fridge. Green temp light flashing for fridge side, freezer side working fine. Fridge side not cooling.
possibly frosted up at the air door between the fridge and freezer, or the fan in the freezer is not pushing cold air into the fridge side, if you can not hear a fan running in the freezer when the fridge is running (compressor on) then change out the fan
Jul 18, 2011 | Kenmore Side by Side Refrigerator
I have a Maytag MSD2142ARW side by side and it has been steadily gettingwarmer on the fridge side. The freezer appears to be cooling fine and I know the fridge gets its cool from the freezer side. The fan...
HI, your Temperature Control Module has failed. it controls the air flow and vent(damper) action. replacing the temp control mod will fix this issue you are having at this time.
Jun 10, 2009 | Maytag Freezers
Fridge freezer over heating and is not cooling fridge section
It is normal for the middle strip to be hot. Did you check the temp setting in the fridge section?
Also - you might check for blockage in the bottom. Excessive dirt/dog hair can block the air flow.
Good luck
Jan 18, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Amana BX22A2W - freezer works, fridge not cooling
Check the damper in the top back of the fresh food section. make sure that it is open and air is coming through it.
Oct 29, 2008 | Amana ABB2227DE Bottom Freezer...
Refrigerator compartment not cooling
If you are sure the fan in the freezer is running and you don't feel any air flow out of the top middle vent inside the fridge section, then the damper motor must be bad. The damper motor is behind that vent cover inside the fridge section.
Nov 16, 2007 | Amana AFD2535DES French Door Refrigerator
Hot Point Side by Side. Freezer works, Fridge not cool enough
check freezer for frost build up and if fan blowing, check condenser make sure clean, and fan blowing, check vents in refrig. make sure no blockage, freezer control should be in the middle setting, you can try turning that to Warmer Freezer allowing MORE air to refrigertor side.
Aug 27, 2007 | Refrigerators
Refrigerators Logo
Top Westinghouse Refrigerators Experts
Dan Webster
Dan Webster
Sheldon Dedek
john h
Are you a Westinghouse Refrigerator Expert? Answer questions, earn points and help others
