Desktop taskbar shows vartically - Office Equipment & Supplies
Posted by nakterbd_09 on
Joseph Mueller
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 346 Answers
Grab the task bar with your mouse and drag it back to the bottom.
simple as that...unless you don't have a mouse ;)
please vote for my fix if it was helpful.
Joe
Posted on Feb 12, 2011
2answers
Lock icons on my gateways computer
Are you talking about the Desktop Icons? Assuming you are, right click on an empty space on the Desktop, click on View, and put a check by Align Icons To Grid. If you are talking about the Taskbar...right click on an empty space on the Taskbar, and then put a check mark by Lock Taskbar...now all your icons are in prison.
The taskbar is upside down and at the top of the screen
On Windows computers, you should have what is known as the taskbar. This is the gray strip that runs across the bottom of your computer and which displays icons for quickly accessing programs you frequently use. The taskbar also shows the "Start" menu, clock and icons for your Internet connections. Sometimes icons do not appear properly in the taskbar. This usually is because the computer is new and hasn't had icons placed in the taskbar manually, or because a default setting is off in the OS properties. Both are simple fixes.
1.Right-click the "Start" icon and select "Properties."
2.Select the "Taskbar" tab in the "Taskbar and Start Menu Properties" dialogue box.
3.Uncheck "Lock the taskbar" and "Auto-hide the taskbar." Check "Show Quick Launch." Since the Quick Launch box isn't available in some systems, you may need to right-click on the taskbar area, choose "Toolbars" and then select "Quick Launch."
4.Navigate to the programs you want to show on the taskbar through the "Start" menu or on your desktop. Right-click the program and drag it to the taskbar. Choose "Create shortcuts here" from the menu that appears. The icon for the program should appear in the taskbar.
How do I show the Internet symbol at the bottom of the desktop screen?
Show the Internet Icon at Taskbar
Right click on Task Bar -> Properties -> Notification Area Tab -> Check Network System Icon Box -> Apply -> OK.
BTW
Symbol=>Icon,
Bottom of the desktop screen=>Taskbar
My start button works fine but nothing else shows up in the taskbar
Your taskbar's properties might be disturbed so by going to the below link you can download the tool to fix the problem
http://www.kellys-korner-xp.com/taskbarplus!.htm
thanks
2answers
On my Vista desktop, the start/taskbar shows up on the right side when it used to be along the bottom of the screen. why did it move and how can i get it back to the bottom?
First, right-click the taskbar. If "Lock the Taskbar" has a check mark next to it, the taskbar is locked. You can unlock it by clicking "Lock the Taskbar" again. Then, click an empty space on the taskbar, hold and drag the taskbar to one of the four edges of the desktop. When the taskbar is where you want it, release the mouse button.
Picthure has gotten shorter and shorter over the last few months and now only fills 1/3 of the screen
this problum is vartical stage in tv set pls check vartical stage capaciter or pf .
470uf/63v /1000uf/63v 4.7uf/50v /0.47uf/50v cheked or Replace all vartical stage capaciter .this problum is not creat long time in futuer.
From about 4 inches down from the top of the tv and from the center to the left corner is red and green and the corners on the bottom of the tv are also arched but not as bad
this is a vartical non linarity folt .
chech vartical stage capaciter 470umf/63v 4.7um/50v 1000/50v
0.47um/63v Replace and first svr.menu to set vartical linyarity adj.
set V- hight is sum down sum 1" or 2 " after the set vartical linyarity V-line. set up to down and check the pictur. if not then Replce capaciter.
1helpful
I run Windows XP Professional. Today there showed up a second layer of taskbar. It has ''Desktop'' in light blue, ''My Documents'' ''My computer'' and ''My Network Places'' shown in white with icons. ...
You have only increased your taskbar size, don't worry...
Right-click on an empty part of the taskbar, and ensure the "lock the taskbar" is unchecked. Next, position your mouse right on the top edge of the taskbar, your mouse should change to two black opposing pointing arrows. Hold left-click, and drag the taskbar down.
This will reduce the taskbar back to the way you're used to.
Hope this helps, and please rate this answer.
1helpful
My ctv vartical hight problam
vertical circuit not working
Tom Chichester
