Canon 2520 ir has a cue and has stopped printing
Posted by svmat2000 on
5 Related Answers
Anonymous
  • 1219 Answers
SOURCE: Solution for canon ir 2520 error code E000020
E020 0000
The path between the sub hopper and the developing
assembly is clogged with toner.
1.Check the rotation of hopper motor gear. (If rotating, false
detection by the sensor is doubted. Feed the toner to the
developing unit in service mode: CLEAR>ENGIN>TNRINST.)
2.Replace the Developing Assembly Toner Sensor (TS1).
3.Replace the Sub Hopper Toner Sensor (TS2).
4.Replace the DC Controller PCB (PCB4).
SERVICE MODE:
* 28 * or MENU and #
Posted on Jul 01, 2010
Anonymous
  • 1219 Answers
SOURCE: what it a finisher for
it is the "device" which is mounted on ir 2520 or any other copier, with purpose to stack, collate or staple the copies. :-)
Hope that helps!
Posted on Jan 10, 2011
nikhil chachapara
  • 140 Answers
SOURCE: canon iR 2520 toner install problem.
u can go in service mode by pressing additional function + 2+8 then go in clear by pressing scrolling, then go in engine. after press ok in tnrinst. machine will process for 2 minutes. for toner installation.
Posted on May 09, 2011
help me please , i fixed finisher ir2520 finished and i open power
finisher is runing left to righ,panel show aready about 2 secon
it show e000716, how can sobe.
Posted on Jul 20, 2012
fivemayur
Sanjay Parihar
  • 414 Answers
SOURCE: solution to errorE000003 0f ir 2520
Press the additionel function button & press 2&8 buttons at once and again press additionel function .select COPIER and FUNCTION and CLEAR and ERROR andpress OK button.
Posted on Feb 26, 2013
My CANON IR 2520 PRINTING VERY DARK SHEET AND SHOW ERROR CODE E000110 THANKS
Try removing ink cartridges and see if anything changes. If printer starts working fine, check which ink cartridge is bad by putting one at a time, or just change ink cartridges.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/alex_22751bbefa74c3d0
Jun 09, 2017 | Canon Office Equipment & Supplies
Canon ir 2520 hang or display sowing canon
hi. maybe there is a problem with the system booting section . try to perform a firmware upgrade
Feb 10, 2016 | Canon imageRUNNER 2520 Laser Multifunction...
How to memory clear canon ir 2520
if this is a printer , go to control panel on the pc, click on printers and devices, click on printer and open up the see what is printing tab
clear all in the que
Nov 04, 2015 | Canon Office Equipment & Supplies
Error 0099 canon image runner
0099 : SMART PANEL Canon-IR-2520-2525-2530: A memory communication reservation has been cancelled.
Looks like it was answered here for a different printer -
http://www.fixya.com/support/t7156967-canon_ir2020i_dasnt_print_error_code
Sep 09, 2014 | Canon imageRUNNER 2525 AllInOne Laser...
Print unable error 7a
Canon copier IR 2520 show error code of E000002 please help me
Oct 30, 2013 | Brother MFC-8880DN Mono Multifunction...
Solution to errorE000003 0f ir 2520
Feb 26, 2013 | Office Equipment & Supplies
CANON IR2520 SHOWING ERROR CODE 804
In my experience the 804 error code relates to the location/availability of a file. If you are trying to print/access a particular file check the path and make sure you have permission to access it.
Dec 28, 2012 | Kodak ESP 3 Multifunction Printer/ Copier/...
My canon image runner 2520 has been duly bought and well powered, but it brings error code e000020 and it does not print or scan,i need immediate help.
the problem is when i have replaced the drum of my canon ir 2520,appeared for me two big black lines and then appeared that code :e000196.thankssssssss.
Jul 20, 2011 | Office Equipment & Supplies
k24674
