SOURCE: 64 bit driver for HP 5470c scanner
Dear go to www.hp.com click on support and drivers then enter your product model now you choose your operating system and download driver free.
First install its software or driver only then you should attach your scanner (when your computer demand or required for its attachment).
Good Luck
SOURCE: Scanjet 5470c with WIndows 7?
better download the latest driver for your scanner from the hp's website and while selecting the new driver you have to specify that you are using windows 7 and also specify if it is 32 bit or 64 bit you will get the driver , install it and connect the scanner it will work ..... thats all....
SOURCE: drivers for hp scanjet 5470c for mac os x
click here
Click on above link and click on mac os x then download driver and install in MAC.
Let me know if you need further assistance.
Thanks for using FixYa.
SOURCE: I can't find a driver to get my HP scanjet 5470c
Hi ,
Scanjet 5470c does'nt work under W 7 . No drivers available .
Here are a few hints :
1° hint :
Do not connect scanner .
Load XP driver ( yes , XP) , reboot , connect scanner and wait for confirmation of successfull operation .
Reboot .
Dowload and install FreeKapture ( yes , it's free ) from http://download.cnet.com/FreeKapture/3000-2094_4-10673689.html
Open Freekapture , clic on Scan and select WIA-Hewlett-Packard . Scanjet 4470c works fine in this mode but if you choose HP PrecisionScan Pro , program will hang .
In any case , no slides or negatives scans possible but the rest works .
2° hint :
If you have the W XP install disc , you could install a virtual version of W XP on your HDD ( http://downloads.vmware.com/d/info/desktop_downloads/vmware_player/3_0 ) You could also partition your HDD ( http://www.partitionwizard.com/free-partition-manager.html ) and install W XP on the new one . Regards
SOURCE: Hi, HP scanjet 5470c scanner
Hi , Here are a few hints : Make sure driver XP ( yes , XP ) is correctly installed . Then , go to http://download.cnet.com/FreeKapture/3000-2094_4-10673689.html and install FreeKapture , it's free . Regards .
if you are actually talking about 5470c and not 2200c , here are a few hints :
Load FreeKapture , clic on Scan and select WIA Hewlett-Packard . Scanner works fine in this mode . If you choose HP PrecisionScan Pro , program will hang .
If you have the W XP install disc , you could install a virtual version of W XP on your HDD ( http://downloads.vmware.com/d/info/desktop_downloads/vmware_player/3_0 ) You could also partition your HDD ( http://www.partitionwizard.com/free-partition-manager.html ) and install W XP on the new one . Otherwise , you will have to buy a new scanner , what you probably already have done .
