Question about Reddy Kerosene Heater with Thermostat: Multi Fuel Master Torpedo Heater with Thermostat Free Ship
When plugging in my reddy heater 110 it blows air & no heat and then goes off.
Posted by elyon466 on
D. Floyd Kolb
  • Reddy Master
  • 43,501 Answers
Here are a couple of tips that I wrote that tell you how to troubleshoot a Torpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters
Torpedo Heater Pump Pressure Adjustment
heatman101
Posted on Feb 15, 2011
Reddy heater blows the fuse in the control panel,
Check out on the nameplate on Reddy Heater how many amps it draws and what size circuit is needed.
It could be that you have an undersized wire and outlet where heater plugs into
Jun 18, 2010 | Reddy Heater-70,000 BTU Kerosene w/T'stat
I have the pro reddy 100 LP. It hasn't been run
replace the thermocouple anyway,it will go bad after time
Dec 24, 2009 | Reddy Heater RLP100 Portable Forced Air...
Ihave an all pro 110 torpedo heater that doesnt ru ichanged all the filters the glow plug works and the eye tells it to shut off but no spray it does spray when i blow thru the hose from the outlet filter...
A small air pump is located on back of motor when sends compressed air into nozzle to lift fuel from tank. It sounds like the rotor portion of your pump is broken
Nov 13, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Bought a reddy heater 155,000 kerosene.It wont draw feul.Hoses are clear (translucent) and also are not plugged. I can blow thru both & hear air come out the oriface. Am try to find out if previous owner...
the fuel line goes to the back of nozzle and the air line goes to the front.the air line and fuel line are not clear on that unit.sounds like some one changed them.also the fuel filter goes in the unit backwards from what the arrow shows.check your air pressure.you need to put a gauge on it so it is correct.
Feb 23, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Pro 110, runs 10 min., blows white smoke ,shuts off
the first thing you need to do is go back to useing K1 kerosene, diesel fuel not only burns dirty but also has a tendency to gel up in cold weather which could be makeing it hard for the heater to draw the proper amount of fuel. To reset the pressure you will need a gage, it should run at about 6-7 psi. you can order a pressure gage from mr. heater online, they are by far the cheapest I have found as they are the actual manufacturer or call 1-800-251-0001
Feb 05, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Reddy heater blows cold air
Here are a couple of tips that I wrote that tell you how to troubleshoot aTorpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters Torpedo Heater Pump Pressure Adjustment
heatman101
Dec 30, 2008 | Reddy HEATER RLP100 100,000-BTU PORTABLE...
Reddy Heater will not ignite flame
Please answer the following questions. There are several folks on the board that can help but we need to know some vital information so we can get started. Answer these, if you can:
  1. Which Pro 110 do you have. We need the exact model number. Pro 110 is a series of heaters.
  2. Does the heater have a spark plug or a glowbar (HSI)?
  3. When the motor runs is it pumping fuel?
  4. When the motor runs is the spark plug firing (or glowbar glowing)?
Nov 13, 2008 | Reddy Heater-170,000 BTU Kerosene Deluxe
Reddy heater pro 110
My best guess is that you are are connecting to your AC receptacle with an extention cord that is too small. The Reddy Heater contains a computer that will shut the unit off if it cannot pull enough amps from your service. The longer the cord the higher the loss from receptacle to unit. This loss can be reduced by increasing the size of your extention cord. I run a 100' 10/2 cord.
Hope this helps!
Handy Home Guy
Boone, NC
HandyHomeGuy.com
Nov 01, 2008 | Reddy Heater-170,000 BTU Kerosene Deluxe
Heating & Cooling Logo
Top Reddy Heating & Cooling Experts
Paul Carew
jdthefixer
Harrie
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
