GE 46GW947 46" Rear Projection Television Logo
Question about GE 46GW947 46" Rear Projection Television
I have a GE Big Screen Tv with Guide plus. model number 46GW948. my son got into factory settings and set the tv in some sort fo 3D setting. the red, green and blue need to be adjusted. Can you help me with this problem? Thanks
Posted by frenchbtc on
  • frenchbtc Feb 22, 2011
    thank you for that advice, but i cant find the menu to adjust that setting. can you tell me how to get that screen. i have looked under every menu option and cant find it.
Anonymous
  • GE Master
  • 3,459 Answers
Please do us a favor and rate this solution after reading.
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set afI have a GE Big - 65af323.jpghange
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on Feb 21, 2011
Removing parental lock on a ge/ modal num 46gw948
I have never seen the 948 have parental control lock---it's too old for support from Thompson (GE/RCA) so I will ask a question: what precisely is the set doing or not doing? Does it have the "Guide Plus" logo on the front of the cabinet?
We need to figure out how to get it off of the 3d setting we just recieved this tv from a friend of ours and we are trying to figure out how to view it without the 3d our tv is a mitsubishi big screen...
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video or dead set) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. In some cases the TV will also not show any video. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
  • Screen looks 3D, wavy, or has a shadow or shadows
69189a5.pngSOLUTION
You can get the correct parts, step by step photo instruction guides, and support from www.TvRepairKits.com or click here
TV set after fluid change
69189a5.pngSOLUTION
2helpful
I turned my tv on this morning and the colors were all out of wack. the tv was producing an image similer to what an old 3d movie with the red and blue images. i tried reseting the tv to factory default...
69189a5.pngSOLUTION
69189a5.pngSOLUTION
The picture is offset far to the left, leaving big black bars on each side. my remotes no longer are able to move the screen manually. I tried to unplug the tv for several hours to reset it and it didn't...
projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
  • Screen looks 3D
69189a5.pngSOLUTION
I have a phillips big screen. The picture looked 3D, so my brother hit the factory reset button and now the colors are off set
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded over.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
3d884ac.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
I have a 48 inch rear projection tv Model #46GW948 Serial #119251338 THE PICTURE CURVES UP FROM THE BOTTOM AND DOWN FROM THE TOP. THE COLORS ARE SEPERATED LIKE ITS 3D. I TRIED USIONG THE SCREEN MENU TO...
this set had a convergence problem where a diode on the separate power board causes the convergence to be way out. Also if it has the "Guide Plus" you may be missing items in the main menu-----in the guide menu set it so you show you have no cable box, no vcr, and set the zip code for 99999----if this has been helpful please indicate with a vote for me.
If the diode is bad---it should be an easy fix for almost any technician who comes to your home.
Ge tv screen look like 3d
Sounds like your convergence circuit is shot.Its the most common failure with rear projection sets since they all use the same type of parts. 90% of the time 2 big IC chips called STKs fail along with maybe a fuse or resistor in that circuit. You could be charged $300-400 depending who you get to repair. Or buy the STKs and try it yourself if your handy with a soldering iron.
Rustym62
The TV Dude
Mitsubishi 290p080020 big screen tv
•Screen looks 3D
•Colors don't line up
•One or more colors can't be adjusted when using the convergence menu.
•Screen is bowed or warped.
•TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems
fcabb43.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya - CLICK HERE
GE 31GT740 TV problem
hit the clear button on the remote and it will clear the guide plus off the screen
2answers
TV problem 46GW948 GE 48? Thomson Guide Plus GemStar
i hope this helps. on the tv, press menu, then channel up or down to "screen", then menu;
then channel up or down for adjust projection tv(6), then press menu;
then use the volume up and down, as well as the channel up and down until each of the 3 colors are lined up. press menu after each color i slined up to go to the next color.
hope this helps.
Open Questions:
See all GE 46GW947 46" Rear Projection Television Questions
Top GE Televison & Video Experts
Jaime Hernandez
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
