Question about Ubi Soft Family Feud Decades for Nintendo Wii
We cannot set up a second remote to play in the 'versus' mode. up to for remotes work on all of our other games. please help!!!
Posted by cueteapie83 on
Anonymous
    New Friend:
I had this same problem until I read this solution that actually worked: Click on the Versus Mode and when the "error message" comes up saying you need to sync another remote, simply click on the "A" button on your second remote. It worked for me...hope it does for you too!
Posted on Mar 01, 2011
After pressing the red sync button on the console for about 10-15 seconds, and syncronizing the remote, the remote stars to work, but when I start a game the remote is no longer working. Then when I...
There are two ways to sync the Wii remote with the Wii console after pressing the red sync button like you did:
1) Press the "1" and "2" buttons on the Wii remote until the lights begin to flash. This method provides a temporary connection to the Wii.
2) Open the battery cover on the Wii remote and press the red button next to the batteries. This creates a permanent connection or "pair" between the Wii remote and the Wii console.
Based on your description, it sounds like you are using method #1. In order to power on the Wii when the Wii's red light is on (meaning the machine is turned off) and start playing games like you want, method #2 must be used.
Imagine method #1 as "guest mode". If a friend comes over with their Wii remote and wants to play a game, you would open up the game first, use method #1, and your friend would temporarily be connected to the Wii. Using method #1 is like "owner mode" that lets the Wii remote turn the console on and off and always stay connected to it.
Hope this helps!
How to get universal remote to turn the tv to game mode
I don't know if this can be done with a universal remote, but if you can let me know which brand and model of universal remote you are using, I will check if it is possible. If your universal remote has an "AV", "SOURCE" or "INPUT" button, try these but make sure the game system is switched on so you are able to see if/when you have changed to the correct mode.
If you don't have the original Symphonic remote, you should be able to switch the TV to game mode using the buttons on the front of the TV as follows:
1. Switch the game system on
2. Press the "MENU" button on the front of the TV
3. Highlight "PICTURE" using the CHANNEL UP/DOWN buttons
4. Press the VOLUME UP button once to enter the PICTURE menu
5. Highlight "GAME MODE" using the CHANNEL UP/DOWN buttons
6. Use the VOLUME UP/DOWN buttons to set "GAME MODE" to "ON"
7. Press "MENU" to exit the menu and play games.
The menu should automatically close anyway if you don't press any buttons for about 15 seconds.
When you have finished playing your game, repeat the above steps to set "GAME MODE" back to "OFF" and return to watching TV.
Hope this helps. Please post back for further assistance if needed.
Regards,
BElectric.
1helpful
3answers
Pressed red button for more than 10 seconds remotes not working help
hai. I am one of the user of wii....... i also got many problem like this..... i solved my problem using wii repair guide....click here to help you........
I bought a second wii remote it is fully charged but it flashes several blue lights then switches itself off! please help
wen you go to play a muliplayer game and the second remote won't turn on automatically wen a button is pressed then with the player one remote go onto the wii menu then go onto wii remote settings ( at the bottom of the screen) then click on reconnect press 1 and 2 at the same time on the player one remote after a while it will turn on the do the same thing with the player 2 remote and it should turn on afer a few seconds
hope that helps =]
1helpful
3answers
Cannot play Tiger Woods PGA 09 with 2 remotes
Tried that, but the 2nd remote won't respond when we try to use it to pick second player. My question is why in the world would someone create a game that is sooooo difficult to play!? Picking two players with two remotes shouldn't be so hard to do!!!
4helpful
How can we set sylvania tv to game mode from the front panel?
hit menu and then hit the up volume button once and thn you should have it by the way i cant play games on mine how r you playing games on yours?
1helpful
Problems with a Wii game
if you are in the mulitplayer mode and still have trouble adding the remote then try syncing the remote with the wii first by pressing the home button then go into the wii remote settings on the bottom then re-sync each control. Then try going back into mulitplayer mode and try again or while the screen is on when you want to add more players press the '+' button.
2answers
Help with Game Mode/Channel Switch Please!
Go to Radio Shack and get an universal remote control, i have a Phillips Universal for mine. it has a tv/vcr button that also is an "input" button to switch channels to do this.
30helpful
4answers
Remote malfunction - panasonic dvd stereo system
The remote control and main unit are factory-set to “REMOTE 1”
mode.
If your remote control affects other equipment during operation, you
can switch to operate in “REMOTE 2” mode.
To switch to “REMOTE 2” mode
1 While pressing and holding [AUX] on the main unit
Press and hold [2] until “REMOTE 2” appears on the
main unit display.
2 Press and hold [ENTER] and [2] for at least 2
seconds.
The main unit and remote control are now set to operate in
“REMOTE 2” mode.
To return to “REMOTE 1” mode
Do steps 1 and 2 above but use [1] instead of [2] for both steps.
(“REMOTE 1” appears on the main unit during step 1.)
The remote control cannot work with the main unit if their
modes are different.
“REMOTE 1” or “REMOTE 2” appears on the main unit display when
you operate the remote control.
If “REMOTE 1” appears (The main unit is in “REMOTE 1” mode.)
Press and hold [ENTER] and [1] on the remote control for at least
2 seconds.
If “REMOTE 2” appears (The main unit is in “REMOTE 2” mode.)
Press and hold [ENTER] and [2] on the remote control for at least
2 seconds.
Ubi Soft Family Feud Decades for Nintendo Wii Logo
Top Ubi Soft Video Game Consoles & Games Experts
Tom Chichester
Are you an Ubi Soft Video Game Console and Game Expert? Answer questions, earn points and help others
