Zinwell zmt-620hd "no signal" The signal is good -
Posted by jknightnz on
Anonymous
    New Friend:
This isn't a solution, I'm afraid, but I believe I have the same problem. My Zinwell ZMT-620HD has failed more gradually. It used to work sometimes, and I thought the aerial was the problem, but even on a good aerial it cannot detect any channels.
Maybe this brand is (expensive) ****?
Posted on Mar 22, 2011
Anonymous
    New Friend:
No solution sorry, but we have the same problem. We get a picture eventually but it is taking longer and longer each time. Once up and running everything is fine, but can take three or four minutes to sort itself out - very frustrating!!! Wish there was an answer to this...
Posted on Jul 05, 2011
No Signal!!!!!
First Option:
Phone in the Other Sim and check the Phone Network Signal If Network Signal Problem not Solved So
Secend Option:
Your Phone Network IC Fault So Please change Network IC
And Network Signal Problem will Solved
if it is there isn't much you can do on this side of the network.
Contact your phone company.
Jul 30, 2012 • Cell Phones
Zinwell DV3 i retuned before transmission resumed and now cannot access the menu options or recorded programmes is there a factory reset i just want to retune it now transmission has resumed.
This sounds as if analog tranmisions have now been switch off at your location. Does your set have a digitall tuner fitted if so select dvt from remote go to install menu and do a full scan > If your set does not have a digatil tuner fitted the you will have to connect a digatil box to your tv.
Regars Derrick
I don't have s stanadard TV set (CRT) with pre-digital tuner. I have a Sony PVM-2950 (2950Q) CRT monitor (no TV signal tuner, dumb tube). It accepts external signal feed. Today, the red...
Hello. You might try to re solder the power supply and deflection area, Also the common problems of this TV are the capacitors that lose value. But I think you have loose connections on the card. Good luck, if you have any questions, I'm here to help you with more details. thanks
I lost my zinwell manual, and i am not sure how long does it stay on if u are not watching t.v.
Hi,here it is..pls visit the URL below to download it..
Hope this helps!..if more help requires pls let me know.
Take care and please
Remember to rate/vote and give me 4 Thumbs Up for me to continue f
or Helping out the Community :)
Zinwell ZAT-970A Digital TV Converter Box Reviews (DTV)This DTV converter box is one of the best all around converter boxes on the market. It has a bunch of excellent features and sells at a great price. This box is one we highly recommend to all. Zinwell ZAT-970A Features & Specs - Zinwell ZAT-970A Owners Manual
http://dtvconverterboxes.blogspot.com/2008/09/zinwell-zat-970a-analog-digital-tv.html
2answers
I need a code to progam this remote to control a zinwell zat857 dtv converter box! please
OK, I have a Zinwell box that was working perfectly until a friend tried it in his new apartment. Two problems (a) he misplaced the remote over there, and (b) he reprogrammed it so it now only gets four crappy channels instead of the previous fifteen.
Will try to get him to search for remote. Meanwhile ar 4am:
I have two universal remotes, old Magnavox and newish Ptimesat. Primesat looks good but doesn't seem to have search fubction -- does it> Tried to get Zinwell to work on Aux wth code 591 but no luck, Search on Magnavox got one partial result but failed again. Help?
(b) Is there any way to reprogram the box manually, without a remote? I want my channels!
2answers
Do you have new codes for the eurovox maxi v
I am sorry but FixYa does not support digital piracy
Sorry about that
When I connect my 8GB Sony walkman to the KCD-W5541U head unit the display shows "Reading" (flashing on/off). Waited for around 10 minutes and still says "Reading". Phoned a friend who...
It may be the format of your walkman is not compatible with your head unit. try turning your walkman off when you connect it, some units will only read when it has uninterrupted access to your walkman's memory
good luck
Open Questions:
Televison & Video Logo
Top Televison & Video Experts
Lawrence Oravetz
