Question about Quik-Lok Quik Lok M 91 Monolith Single Tier Keyboard Stand
Quiklok describes the stand as 'folds flat and locks'. I have two of these stands, and neither one 'locks' - actually they keep unfolding while carrying and hitting one in the shins. Is there a special procedure to get them to lock, or is it just false advertising?
Posted by pianokim on
Fred Yearian
  • Quik-Lok Master
  • 5,603 Answers
I would expect it to lock OPEN, not so in shipping mode... Isn't that a pain... our language doesn't really cover this... and advertisements make good use of the ambiguity to get us excited so we will buy....
Consider using a couple of bungee cords while transporting to solve the problem.
Posted on Feb 12, 2011
Cant put casio 210 tonebank on its stand
What type stand is it?
Feb 21, 2013 | Music
Pro Line mic stand
In most of these stands, there is a nylon ring (similar to a PVC plumbing connector). In cases where it may have been over-tightened in the past, the ring may lose its ability to "lock" onto the tube that runs through the middle. Disassemble the unit, and look for any cracks in the ring or the grip. Cracks in the grip can cause this to fail as well. Good luck! :)
Jan 14, 2013 | Pro Line ProLine Desktop Mic Stand, Black
Keyboard stand by casio seems to have no support to hold the keyboard. The keyboard slides from side to side on the stand
Just add some adhesive Velcro (hook and loop fastener) The industrial rated for 25 pound should be good for most players, 75 pound rated minimum for Jerry Lee Lewis type players.
Set the stand at the height you want, put the hook tape on the stand leg top and then target the fuzzy strip to the piano. Be aware the pound rating is rated per square inch- so you will want to put a 10 or 12 inch strip of fuzzy on the piano, and 1 or 2 inch strips on the stand leg.
Apr 01, 2012 | Music
Need to identify and find parts for the Pearl FZH725/C85 Drum Kit. It was delivered with missing parts. Specifically Floor tom, 14" tom and arms to hold it. Need some direction and guidance, thanks.
I am a drummer as well in a classic rock band. Most the time when I need a part for something for my drums. I will go to guitar center. But to save money eBay is your best bet. You go to guitar center to make sure you have the right part, but don't buy it there . Match it up and go to eBay, lot of drum companies use eBay to sell there stuff. Thanks mike
Jul 22, 2011 | Pearl Forum FZH725/C85 Drum Kit, Zenith...
The clamp on the top of the stand that holds the cymbal down is stuck and cannot be screwed off. My cymbal is stuck on the stand, and its extremely difficult to transport now.
Try lubricating it with a penetrating oil such as "Blaster: or other brand available in automobile parts stores. Let the oil penetrate a bit before trying to unscrew it...
Also you can try heating it with a hair dryer to help break it loose.
When finally free, spray some CRC226 periodically on it to keep it free... You can get that at Home Depot in the electrical dept.
Jan 28, 2011 | Pearl C70w Double Braced Cymbal Stand -...
My keyboard has 2 threaded holes in the bottom that look like they'd be used to attach it to a stand. So...how do I secure it so it doesn't fall off when my dog bumps the stand?
Unless the stand was specifically made for the Casio, the holes probably will not line up with anything. You can COUNT on them being Metric threaded and you have to be careful to not put too long screws in the holes. If you stand doen't line up with the holes, best to secure a piece of plywood to your stand first that is drilled to match the synth and attach the synth to the plywood. I don't know how your stand is made so I can't give you more details.
Jan 09, 2011 | Casio WK200 76Key Digital Keyboard
How do I attach an X frame stand to a casio electronic keyboard
Usually the keyboard sits on top of the X stand held by its own weight. Most of the smaller consumer keyboards do NOT have mounting holes for attaching stands. Piano keyboards that have 88 keys do usually have mounting holes as they are heavier. Most X stands have rubber ends on the tubes where the keyboard sets.
Dec 27, 2010 | Casio Ctk 496 Electronic Keyboard with 61...
Can the color wheel be replace?
The short answer is yes, but that opens up more questions.
1) Is this unit under warranty? If so, opening it up will void hte warranty.
2) Are you sure that the color wheel is the problem?
Can you describe the problem you are having? Perhaps there is another solution.
Thanks,
Dan
Dec 07, 2010 | Chauvet Followspot 400g with Stand
Proline Piano Keyboard Stand Assembly Hi, I just bought a Proline piano stand for an electronic keyboard, and the first step on the assembly directions is to move the clutch to the middle position....
Normally on my stand like this you PULL the knob outward (not turn it) to disengage the pin from the plate with the holes in it... Works quite well and the stand is moree stable than many.
Nov 28, 2010 | Pro Line Proline Pl 400 Double X Braced...
Assembling Odyssey Lstand
lol....after reading your problem and then posting mine I had an idea. I went to youtube.com and found out that in order to hook up the U CLAMPS...you have to disconnect the table top attachment and connect the U Clamps to the short bases. You then dont need longer screws you use the little black screws that came with the stand. I went to Guitar Center after I did mine and confirmed that theirs was set up the same way....lol...LETS PARTY NOW !! This calls for a celebration party...lol GOOD LUCK AND TEAR THOSE PARTIES UP
Jan 28, 2009 | Odyssey Lstand Laptop Stand
Quik-Lok Quik Lok M 91 Monolith Single Tier Keyboard Stand Logo
Top Quik-Lok Music Experts
ADMIN Canada
ADMIN Canada
ray gallant
rhodesworks
Are you a Quik-Lok Music Expert? Answer questions, earn points and help others
