Question about Kenmore Washing Machines
My washing machine model #110.20712.990 has stopped and when I turn the swith to spin it does nothing.
Posted by dreamangels6 on
5 Related Answers
john mc donald
  • 121 Answers
SOURCE: My washing machine has stopped spinning.
it sound like your belt has come off if not wait till its dark put it on spin turn the light off if you can see flashes coming from under the machine it your brushes that need replaced on the motor
Posted on Mar 03, 2008
Anonymous
SOURCE: ariston margherita washing machine
I have an old Margherita washing machine year 2000, my problem I don't have user's manual. Can you please provide me or teach me how to operate the machine?
Thanks & regards
ray salac
Posted on Sep 03, 2008
Anonymous
  • 1122 Answers
SOURCE: Machine doesnot agitate or drain once filled with water
it sounds like a bad lid switch if it will not drain or spin,the switch controls that-mike
Posted on Apr 24, 2009
cj2176
Chris Jones
  • 520 Answers
SOURCE: my kenmore washer 70 series model 20712 990 will
This model has a safety switch in the door switch. This switch goes bad and the machine will not spin or agitate. Have that replaced and you will be back in business. Hope this helped you out. Good luck.
Posted on Jun 05, 2009
davidpenman
David Penman
  • 255 Answers
SOURCE: My washing machine won't turn or spin.
ok on the bottom there is a donut looking connector with holes and it needs replaced unless its belt drivin
Posted on Aug 14, 2009
Model Gw709AU
When you start your machine is the water just go stop go stop,
Just wait for the machine to display an error code on the wash progress lights and beeps constantly.
It could be the Rotor Position Sensor, out of balance switch or lid magnetic reed switch.
Your error code will determine this.
Is your machine beeping & showing a weird pattern of lights on the wash cycle, It is displaying an error code,
To read this error code you start at the red spin light & work to the left only add up the lights that are on. Red spin light = 1 2nd rinse light =2 1st rinse light =4 last wash light=8 4th wash light=16 3rd wash light=32 2nd wash light=64 1st wash light=128
j8paojvh5jrgaaaaabjru5erkjggg==
Feb 20, 2013 | Fisher and Paykel Washing Machines
Washing Machine won't spin
Could be worn carbon brushes, or possibly defective shock absorbers
Mar 26, 2017 | Tecnik TKL9290 Front Load Washer / Dryer
Does not spin
There is a coupling that connects the motor to the transmission it about a 5 dollar part. Turn the washer on it's side and look at the motor in between you will see the coupling.
Nov 26, 2008 | Kenmore 24032\24036 Top Load Washer
Keep spinning
sounds as if hte tub block has gone bad. its the locking block that ties the inner tub t the transmission shaft, after it strips out nothing stops free rotation of inner basket.
Nov 05, 2008 | Kenmore 24032\24036 Top Load Washer
Maytag MAV6257AWW Washer
Could you describe the noise you are hearing. This will help to determine what to look for.
Jan 13, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Frigidaire Wash Machine
It may be it the Lid switch... bad lids swithes will stop washers from going into the spin and pump out cycle...
Sep 11, 2007 | Frigidaire GLWS1233A Top Load Washer
Washing Machines Logo
Michael Thomas
Michael Thomas
Paul Carew
Lawrence Oravetz
