Question about Connex 3300 240-Channels Base CB Radio
How to convert a connex 3400 hp to cb radio band from 10 meter band.
Posted by jmckinney101 on
AnyMHz.com
    Novelist:
  • Connex Expert
  • 500 Answers
That needs to be done by someone that knows how, theres soldering involved. most cb shops will do it for $free-$10.00... Don't pay any more than that.. there are no parts nor is it hard so they shouldn't charge much.
Posted on Mar 01, 2011
How do I convert my connex 4400 turbo from 10 meter to regular cb channel. I have the module to do so, but not sure what to do with it.
Your connex should have a know with letters on it A,B,C,D,E,F, Look at the counter and set that knob to C whick should be the CB frequency.
Feb 09, 2016 | Connex Radio Communications
Connex 3400 hp makes static noise when I hit bumps in road.
don't hit any more bumps. The problem could be in several areas. I'm going to say that you may have a loose capacitor inside If I had the radio here I could fix it but because the problem may be so spread it could be a lot of things Are you a truck driver? If you are take it to a CB shop at one of the many truck stops and see if they can fix it for you .
Jan 22, 2016 | Connex CX-3400hp AM/FM 10 Meter Amateur...
Just bought a connex coyote hunter.the antenna i have is for cb i know that for 10 meter radios you have to have a antenna thats tuned.on cb band shouldn't i be able to hear On cb band? With cb ant?
The antennae has to be tuned for the radio not for the band you are listening to. If is a 10 metre band, so you need a 10 metre antennae which enables you to listen to both bands, but looking at the jpg of the radio it gives bands A, B, C, and D, nothing about CB radio itself, but the option of AM and FM radio.. Using the wrong antennae could damage it.
you could get some help here
http://www.cbradiotalk.com/viewtopic.php?f=9&t=29531
specs here
Picture and Specifications of the Connex Connex Hunter Mobile Export Radio
Dec 12, 2015 | Connex Radio Communications
I have a Connex 3400 Hp and it stopped receiving all of a sudden while driving down the road and the needle on my meter is dead on 0. I've doubled check to make sure all my knobs and switches we're in the...
check for a fuse bulb for the RX section i would have a radio engineer look at it as you smell stuff
its also not a good idea to drive around with known faulty electronics in your car its a bad problem just waiting too blow up in your face... so.. dont leave electrical issue in cars your family depends on
Feb 16, 2014 | Connex CX-3400hp AM/FM 10 Meter Amateur...
Converting 10 meter to 11 meter on Connex CX-3400HP CB RADIO
Turn the mode switch to the setting you want and leave it there .
Jan 10, 2014 | Connex CX-3400hp AM/FM 10 Meter Amateur...
Fix my connex 3400 hb sideband button
Hi there, if you are talking about the Connex CX 3400 HP there is no sideband or SSB on this radio. It is only AM and FM 10 meter Ham radio. Many people do modify these radios to include the 11 meter frequencies which is the CB band. Maybe knowing the actual bands and their frequencies will help some too this radio does have 6 different bands ranging from (Band A. 28.015 thru 28.455) (Band B. 28.145 thru 28.585) (Band C. 28.115 thru 28.555) (Band D. 28.085 thru 28.525) (Band E. 28.055 thru 28.495) (Band F. 28.025 thru 28.465.) I hope this will help you. Bob
May 13, 2012 | Connex CX-3400hp AM/FM 10 Meter Amateur...
My friend would like to purchase a Connex CX 3400 HP. The store told him that it has to be converted to a CB radio. But they can't do it because its illegal. Can you explain this to me?
These radios are know as what's called 'export' radios. They are imported under the auspices of being a 10 Meter Amateur radio and then through a typically easy modification are made to allow the selection of US CB channels. usually the modification involves plugging in a loose connector inside the radio radio chassis and/or removing a jumper wire soldered to a circuit board. If there is a nearby CB Shop they will usually do this for a modest fee.
Keep in mind that a radio needs to be Type Accepted by the FCC to be legal to use on the CB band in the US and export radios typically are not. Be sure to check the rear label for an FCC ID number.
Feb 12, 2010 | Connex 3300 240-Channels Base CB Radio
10 meter portable
There is no factory made 10 meter CB Radio made for US use. CB Radios use 11 meters, and the FCC doesn't allow the combination of 10 and 11 meter radios combines. Although, many people modify 10 meter radios to work on the 11 meter ( CB ) band, it's not legal. Good Luck
Ed
NC Electronic
Mills, Wyoming
Dec 15, 2007 | Magnum 257 CB Radio
Switching radio bands
what radio do you have? does it even have sideband channels? some radios don't come with them, of fm or upper or lower side bands and short wave
Dec 08, 2007 | Connex 3300 240-Channels Base CB Radio
Owners manual
You can get the ownwers from a website called cb tricks
Jul 10, 2007 | Connex 3300 240-Channels Base CB Radio
Connex 3300 240-Channels Base CB Radio Logo
1,389 people viewed this question
Top Connex Radio Communications Experts
Tony Raia
Marvin
Marvin
Are you a Connex Radio Communication Expert? Answer questions, earn points and help others
