Question about Refrigerators
We just bought a house w/ a older sub zero 632 side by side refrigerator. The previous owner put a thin veneer wood panel on the front w/ antlers for the handles. I purchased a stainless panel kit and the tubular handles to replace the wood and antlers......but now that we have removed the antlers and wood panel, there is no screws to attach the new tubular handles on. They are made with a
Anonymous
    Scholar:
  • 79 Answers
Looks like your question got cut-off, but it sounds like you're asking how to mount the new panel kit and handles, correct? If you haven't already, download the panel guide for the 600-series
http://www.subzero.com/resources/products/downloads/600-430%20panels%20specs.pdf
Posted on Feb 12, 2011
  • Anonymous Feb 12, 2011
    Thank you! I have been researching this all night. I have seen the panel guide...not much help. But I have found that we are missing the "handle mount screw". This part comes out of the panel and the tubular handle slides over the top od it. So I need to get this part and then figure out how to put it on the panel, because as far as I can tell, it usually comes already installed.
Grant Smith
    Champion:
  • 246 Answers
Changing the look of your appliances can be easier. Check out these guys in the future...
www.applianceart.com
Lots of options to change the look of your appliances including stainless steel.
Posted on Mar 14, 2011
Sub zero refrigerators 632 door won't stay closed
Thee is a plastic cam at the bottom hinge of the door. Mine cracked and I bought a new one online for like $30 (for a piece of plastic). Got a strong friend to lift the door off the hinges while I replaced it. make sure you get the right one for left or right doors.
7014663 Sub Zero Refrigerator Bottom Cabinet Hinge Cam LH (7014663) (7014663) - Genuine Refrigerator Parts
Sep 01, 2014 | Sub-Zero 632 / S
Sub zero leaks water
You need to replace that water line, except it's not on top on a 632. And those weren't available in 1994. Do you maybe have a 590?
Jun 26, 2014 | Sub-Zero 632 / S
Lights all went out in refrigerator side of Sub Zero 632
I WILL BET THEY ARE DISCONNECTED !!!! CHECK FOR CONTINUITY AND SEE WHERE THE CONNECTION IS OUT.
Oct 13, 2012 | Sub-Zero 632 / S
I need to remove the wood door panels on my sub zero to repair a door handle
I have subzero 642 but it should be the same. Remove 2 screws on the top edge of the door. The screws attach a metal track to the top of the door and the track needs to be loosened to allow the front wood panel to slide out. Next on the side edge of the door are 3 metal strips. The middle one is held in place simply by magnets and slots at the top and bottom edges of the door. You can remove the middle strip by lifting it out in the middle with a small screwdriver and pulling it off. This will expose 3 or 4 screws that hold a metal track to the side edge of the door. Remove these screws and the metallic track on the side edge of the door. You can then slide the wood door panel out enough to expose the 2 screws that the door handle attaches to. Good luck!
May 16, 2010 | Sub-Zero 632 / S
Sub zero 632
3C on the fridge side
-18C on the freezer side
Sub-zero repair in Orange County, CA
Jan 30, 2010 | Sub-Zero 632 / S
How can i find stainless steel panels for the front of my sub zero model 590
We are factory authorized Sub Zero parts and service. Please contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service from 7 Am until 9 PM CST for all your Sub Zero parts and supplies.
We look forward to hearing from you. Thanks, Ella
Nov 13, 2009 | Sub-Zero 30.1 cu. ft. Cabinet Depth...
Ice drawer
Call the factory at 800-222-7820 they will walk you through it and send you a manual.
Oct 23, 2008 | Sub-Zero 632 / S
Cannot get ice drawer back on the track 500 series
Unfortunately, you need defrost freezer - put freezer thermostat on OFF. You possibly got broken ice tray or damaged sliders.Or leak in ice maker area. Till you defrost that compartment - no chance to pull tray out.
HTML clipboard_______________________________
http://www.subzerolosangeles.com
Los Angeles Sub-Zero refrigeration experts
Jul 23, 2008 | Sub-Zero 632 / S
Refrigerators Logo
Top Refrigerators Experts
Dan Webster
Dan Webster
john h
