On a N95 fill the water container and take it off the machine if it leaks its just the red seal on the botton but if thats not it put the water container back on full of water,let it sit for a bit,it wil leak out the front or side it will be the dark grey seal in the base were the outlet of the water container sits in, I found this with vmine anyway,it was hard to see it leaking but was a pain in the but!! i will talk to Delonghi or pull the seal out and match one the same
Ant
Our machine leaks water when making a coffee. I removed the left sue panel to find there is a silver metal cylinder thing in the back that has heavy corrosion on the bottom. I would say it holds the heating element. Disappointing to see that much corrosion inside like that.
SOURCE: water leaks from the top of the C190 Espresso Machine
in our case the problem was fixed easily: the metal piece in which the capsule sits is screwed in on the top. When it became loose our machine started to leak water from the top. So the problem was solved by retightening it!
SOURCE: Nespresso Essenza C100 leaks all the water out
I have a nespresso type D90 which does exactly the same thing so it is probably not just yours
SOURCE: water not coming through nozzle of nespresso essenza
I have had this issue.
I have removed round silver plastic piece from around coffee spout,(gently -do not crack it) I then removed and washed the black spout, I even used a toothpick once, to remove the stubborn coffee ground, Once it was cleaned - it worked perfect. If you run water from the faucet into spout it should flow smoothly. I warn you though, not sure what this does to any warranty, but don't mess with my morning coffee! I hope this helps.
SOURCE: WHEN SWITCHED OFF, WATER LEAKS AT THE BASE OF
Water leaks from the bottom of the nespresso essenza machine, why?
machine will not power on
