In order to get your router back to the original settings, you must push
in the reset button (usually on the back of the router) for somewhere
between 10 and 30 seconds depending on the router. You may need a pin or
something small to push in the button, because it can be recessed. Once
you have reset the router, the username and password will be changed to
the defaults, admin and password, respectively. One thing you must
remember is that resetting the router will change all of the router
settings back to the factory settings. This means you will lose all of
the changes you made since you got the router. Make sure to write down
any things you've changed, so you can change them back after the reset.
Also, I recommend updating to the latest firmware after the reset.
There a great article at General Router Setup.
If you need more help post back!
Thumbs and testimonial are welcome!
You will find ADMINISTRATION tab in
the upper right hand corner.
click on the
administration tab. just below the administration
tab you will find firmware upgrade sub
tab. Click on Firmware upgrade.
Now on this window you
will find browse option.
click on the browse button and select the firmware file that you have
downloaded on the computer. after selecting the proper file click Upgrade. The
upgrade process will start.
It may take 2 to 5 minutes.
once
you upgrade the firmware of the router, unplug the power cable of the
router , wait for 5 seconds and plug it back in.
For Netgear router
# Click Maintenance > Router
Upgrade
# Click Browse and find the file you just
downloaded.
# Click Upload. Do not interrupt the
upgrade while the router does this step.
It may
once you upgrade the firmware of the
router, unplug the power cable of the router , wait for 5 seconds and
plug it back in.
For Belkin router
Open a
web browser on the computer.
In the
address bar of the web browser, type http://192.168.2.1 and press Enter
on your keyboard.
Click
Login in the upper right-hand corner of the page.
The router does not ship with a password, so just
click Submit.
Click on "Firmware Update" toward the bottom of
the left-hand menu.
Now on
this window you will find browse option.
It may
once you
For D-link Router
Open the web interface of the router.
Go to TOOLS
Under tools you will find FIRMWARE.
Now on this window you will find browse
option. click on the browse button and select the firmware file that you
have downloaded on the computer. after selecting the proper file click Upgrade. The
It may
once you
