Question about Ovens
Oven does not work. Display shows "E13" Thx
Posted by c_haydon on
Richard Roth
    Top Expert:
  • 9,472 Answers
Is this a range or microwave oven? What is your model number?
Posted on Feb 12, 2011
What is the problem when there is an error message of e13 and e13?
Hello friend, that's a great question!
Based off what you have provided your Frigidaire oven is displaying an error code of "E13" and you would like to know what is causing this problem. The error code "E13" stands for a bad EEPROM (Erasable Programmable Read Only Memory) and this could be an issue with the UIB (User Interface Board). This electrical component may need to be replaced however this is not a simple DIY job. I would recommend speaking with a professional technician for proper diagnosis and repairs. This will prevent you from making unnecessary part purchases. -Matt
Mar 16, 2015 | Frigidaire Ovens
My oven doesn't heat up
It could be the switch or heating element
Mar 17, 2013 | Thermador SM272 Electric Double Oven
Frigidaire plef398dca
Hello Bill Robbins - From what you are describing it sounds like a wiring failure or a communication break failure between the power board and UIB has occurred. Error code F5, typically indicates that the EOC will need replacing. A certified technician will need to test the wiring harness between the ESC, UIB and EOC.
Jan 21, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
My Kenmore 911-4298814 oven won't hold broil or bake temp setting. The oven powers on with no error. When I press the "Bake" and dial up a temperature to (say) 350 degrees, the LCD displays...
just had similar problem with frigidaire, temp display would go blank, not even show clock, i took off back of stove, the circuit board would wiggle. when i pushed in on the circuit board it worked correctly.
Oct 30, 2011 | Ovens
Gorenje EI44A1-T34 or EI44A2-T44 Dear Sirs,we have the oven for quite a while,but never used the oven part of this induction oven. And therefor didn't bother too much with the blinking light showing...
I hope you have found already solution for this... Anyway this may help others: press buttons 1 and 2 together and release. Then use jog wheel to adjust time. Wait 5 seconds and you're done. Gorenje manual sucks, no info about oven controls. I managed even to set on oven child lock (key symbol), only way to take it off was to remove fuses from electric board of our house!
Jun 24, 2011 | Ovens
My oven display has "sABBATH" written on the
May I get the make and model # to help you more. On some ovens if you hold the clock button for secondes it should turn off. I need the make and model # to be-sure.
Apr 24, 2011 | Maytag 24" Built-In Single Electric Wall...
How to set time with new control board?
You may set the clock on your Microwave per page 6 of the User Guide by following the steps below. We've included the link for the User Guide below.https://www.whirlpool.com/content/dam/global/documents/200105/owners-manual-8300610.pdf
This is a 12 hour clock and does not show a.m. or p.m. To Set: Before setting, make sure the oven, Timer and Timed Cooking are off. 1. Press CLOCK. 2. Press the HR or MIN "up" or "down" arrow pads to set the time of day. 3. Press CLOCK or START/ENTER. To Disable: The clock time can be disabled so that it does not show on the display. To disable, press and hold CLOCK for 5 seconds. To display the clock time again, press and hold CLOCK for 5 seconds and the time of day will show on the display. The clock time should not have to be reset.
Nov 03, 2017 | Whirlpool GMC305PD Electric Single Oven
SMEG SUK62 MFX
check stat is not open circuit and check selector switch not damaged
Oct 18, 2008 | Smeg SE250XUK Stainless Steel Electric...
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
Michael Thomas
Michael Thomas
Are you an Oven Expert? Answer questions, earn points and help others
