you asked again,. and still fail to say what you are doing so we have
some idea, of what part this is.?
"I can see the conn"., on what diagram of what system in the car
the radio., head end, or amp or ?
the spark generation, parts. of the engine.
fuel injectors can have , noise reduction on some engines
no engine stated, so, no answers ever lacking that.
where>????? there are 3000 parts in the car,
is there a problem? non stated, yet.
the engine line up is: in one other anon post you said, 2.3L
but failed to say, what the problem is, not even the slightest hint of what you are attempting....
please do tell.
1.3 L
I4; 1.5
L I4; 1.6 L I4; 1.8 L I4; 2.0 L I4; 2.3 L I4; 1.4 L
Diesel I4
the FSM covers all this, and in FACT shows every connector in the car.
ever seen the REAL deal, a real FSM (factory service manual)
try this. for 4 bucks.
here it is. this covers the USA versions.
https://suzukipitstopplus.com/Products/1004-2004-aerio-service-manual.aspx
no country ?
no engine (2.3L) (anonymous post do make this hard no?)
no system stated.
no issues , problems or goals stated.
Thanks for the response,however I need the original information on the mechanism and how to service that. If you can send the information on it I would be most appreciative. I assume it may have been available in the Lionel service manuals or possibly in the original operators instruction sheet that came with the accessory dating back to the 50's.I run older equipment so your answer was a little more complex than I expected,interesting extra effect though,I just may have to move into the twenty first century.Hopefully you can find the info I need until then thanks for the help.
sincerely; kb_at_3
hihere you can see your solution..that will help you..see herehttp://www.transitionsmobility.com
