I would venture a guess that the cable you are using in the vehicle is not a genuine Garmin cable. The units are very sensitive to voltage.
Anything under approximately 10 volts - the Garmin assumes it is plugged into a USB port (Active Cradle)... not a vehicle... and it dims for quicker charging.
Switch to a Garmin OEM cable.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
I spoke to Garmin Support about this issue. There are 2 settings for contrast on the nuvi 1300. You need to set the contrast while it is plugged into the vehicle, and also while it is unplugged from the vehicle. The reason for the 2 settings is to save the charge of the battery while it is not plugged into the vehicle or power source.
Have you tried doing a hard reset,try using the reset button on the bottom of the gps under the serial label.Or try holding the turn off button for about 10 seconds,good luck.
I connected the unit to the car charger instead of the USB charger and then held down the reset for 10-15 seconds, after which the system would show the computer connection on the charger and then boot up when not on the charger.
If you left your Garmin c330 on running
the battery will have 1% life left. If you turn c330 back on again, it
will flash screen for 3 seconds then die, even charging it at this
point will not wake it back up. TO BRING IT BACK TO LIFE... plug in the
power home or car into Garmin c330. There is a tab in the front Garmin
gray frame of your screen. You must take like your fingernails and
under the logo "GARMIN" pull the whole gray plastic frame off.
Underneath the plastic frame to the right hand side. There is a "RESET"
button. Make sure power is plugged in while hitting reset. Your battery
should come back to life. Cheers
easy solution...you need to keep this plug above attach to the the Garmin 350...when charging in the car or at home ...plug the power source to the back. Hope this will help...i had the same problem.
