Question about Panasonic Lumix DMC-LZ2 Digital Camera
Why does my SD card for my camera need to be re-formatted and I've already been using it?
Posted by micky_mcj on
Anonymous
    New Friend:
  • 69 Answers
Usually it happens when an SD card get corrupted. The usual cause for faulty SD cards is when it is not properly disconnected from the computer using the "Safely remove" function.
Posted on Feb 11, 2011
How i can format my sd card for vtech camera
1. The camera will format by itself.
2. or Use any already formatted SD card.
3. or in most camera setup mode, there will be an option to format the SD Card.
Apr 05, 2016 | Vtech Cameras
How do I format the Sandisk Ultra 30 mb/s 16 gb for my Kodak Easyshare camera Z650 Thought it should have been already formatted for camera use.
Your camera, only can hold MMC and SD cards. SD cards only go to 2 Gbyte, but be aware most 2 Gbyte cards now in the stores are already SDHC. And those you also can't use.
So try to get a real SD card for this camera.
I did write lots of things about SD, SDHC and SDXC cards, so feel free to search some and read them.
Sep 10, 2014 | Cameras
HOW TO FORMAT CARD FOR KODAK C703 CAMERA
In settings you find (on the bottom) Format.
You could try formatting in a computer, using an external card reader and choose the FAT16 or FAT 32 format.
But be aware if you bought a new memory card it should be a SD card. Not a SDHC or worse SDXC.
The camera can only handle MMC and SD cards. Today you can't find much SD cards. Because they already started to make the 2Gb cards in SDHC. (High Capacity) these cards look the same, but can't be accessed if your system (Camera) can't handle the large file systems.
So if you need a new card, look for the smaller like 1 or 2 Gb, but with only SD printed on them. As soon as you see SDHC or SDXC you can't use them in this camera. The newer ones can.
Jul 15, 2014 | Kodak Cameras
Konica minolta DiMage Z10 doesn't recognize sd card
Might one enquire how you have assessed the intelligence of the connecting lead ? I know of no definitive tests for this area of electronic equipment.
Mar 16, 2017 | Konica Minolta DiMAGE Z10 Digital Camera
I just opened a brand new SD card and tried to use it with my P850, but when I insert the memory card it says "Memory card is unusable. Insert new memory card." I've tried formatting and...
If you just purchased this camera, you can try phoning place of purchase or make a trip there. It sounds as if the software in camera may be messed up.
Sep 18, 2011 | Kodak EasyShare P850 Digital Camera
I have a Kodak EasyShare C330. I have a new memory card Kodak SD Card 128MB. When I insert it in the camera, a message displays stating memory full. When I try to format the card to the camera I received...
This error message means that the card is corrupted or formatted for another digital camera. Turn off the camera. Insert a new card or format the card.
Try to format the memmory card using a card reader and the PC this should solve your problem if not you have to replace the memmory card.
Mar 11, 2011 | Kodak EasyShare C330 Digital Camera
Comes up with format then check sd card
I've had this problem too.
Your Samsung Digimax L80 accepts SD Card cards.The largest SD Card card you can use in your Samsung Digimax L80 is 2GB anything larger and it doesn't work.
Jun 03, 2010 | Samsung Digimax L80 Digital Camera
My vpc-hd2000 dual camera asks do i want to format my sd card
Use a separate card reader to download your pics to a computer...then, format the card in the camera.
Dec 15, 2009 | Cameras
Panasonic Lumix DMC-LZ2 Digital Camera Logo
Top Panasonic Cameras Experts
STEVE
deton8 von Splosion
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
