Question about Toshiba Computers & Internet
This computer worked fine for two years and then started freezing up and had to be hard booted each time. The problem got worse but never predictable as to time frame. Seemed to be only when connected to a/c but later on battery also. I have had the hard drive replaced, the ram memory and the operating system from vista to xp pro with no help.I have the unit down to the mother board and the heat sink is clean. What next? Thanks in advance.
Posted by dan_butts on
  • dan_butts Feb 11, 2011
    With your answer I checked on a replacement. I have a new Toshiba 655 that uses the same ac adapter. I have used it to charge the Toshiba p205d
    in question. I'm pretty certain that this eliminates the adapter issue?
    I have two Toshiba computers and they use the same ac adapters. I have used the charger from my A665 computer to charge the old P205. It didn't make any difference, same problems.
Benjamin Jr Singson
    Genius:
  • 1,570 Answers
Hi Can you please your laptop without the battery, Just plug the power cable in your laptop. Check if the same problem occurs?
Posted on Feb 12, 2011
Toby Lee
  • 409 Answers
It's possible the ac adapter may be faulty and is putting out the wrong voltage.The voltage being wrong can cause freezing,touch pad problems,etc.Other than that it would most likely still be one of the things you said you replaced that's bad.Usually the hard drive.
Posted on Feb 11, 2011
No boot, one long beep at startup.
take it to a computer repair shop
indicates hard drive failure
Jan 18, 2018 | Intel DP55WB Motherboard
SMART FAILURE PREDICTED ON HARD DISK 2 TOSHIBA MK2035GSS (S1) PRESS F1 TO CONTINUE. ON START UP COMPUTER GOES TO THIS SCREEN EVERY OPTION ON START UP OF F1 DOES NOT START WINDOWS AND COMPUTER RETURNS TO...
As I understand it, SMART is correct 50-60% of the time...means it's wrong 40-50% of the time.But..You can't take the risk, you have to assume something is wrong with your hard drive. So, i f you have important data there, go to a repair shop and they can save data from your hard drive and replace it, if necessary. If you want to solve it on our own, you need a boot cd with error checking. Any live boot cd with linux does that. Also, there are several live boot cds like Hiren's Boot, with rescue options.
May 11, 2011 | Computers & Internet
Smart Failure Predicted on Hard Disk 4
Are you sure you don't have a usb or other device plugged into your computer. Your main hard drive should be disc 0. Disc 4 is usually a disc further down the line, like an external or something like that. If it indeed the case then you may be having a problem with the boot in your primary drive. Try booting the disc with a windows installation disc. load the dosc and boot, when it says so, hit any key to boot off cd. When windows loads, hit repair this installation. It will reboot when it is ready. If that doesn't take care of it, reload the disc again and try to restore the drive to an earlier time, like a day or two ago. If this doesn't work, you may have to get another hard drive and reload the system. Don't get rod of the other hard drive though because you may still be able to access the personal files off of it as long as it hasn't had a mechanical or electrical problem keeping it from spinning.
Sep 13, 2009 | Dell Inspiron 1501 Notebook
Lacie 750 GB External hard drive
Dear,
Please check your BIOS setting. Make sure that Boot from USB device/drive is disable.
Reply....
Regards,
Rakesh Kumar
Mar 31, 2009 | Computers & Internet
My computer comes up with a black screen
try and start in safe mode
then see if your driver is correct in my computer property hardware devices
Jan 17, 2009 | ATI RADEON HD 2400 PRO Graphic Card
Tecra 8100 Freezes shortly after Windows comes up
Go into your hard disk utility and defragment your file. When the computer writes to your hard disk over time these files no longer are sequential as they were in the beginning. This is one solution, also you can do a disk recovery using your original disk or by pressing F10 as it boots up. Be sure and do a good check for viruses as well. The symptom you are describing sounds alot like a virus that is slowing your system down more and more. Good luck.
Jan 14, 2009 | Toshiba Tecra 8100 Notebook
I have a Maxtor 3200 USB drive. It stopped working and dont know why Has Error 10. I try to reboot computer, but everytime i do this the computer freezes. I guess the computer has a hard time figuring...
hi
please pres dell WHILE BOOTING YOUR SYSTEM GO TO THE BIOS AND BOOT OPTION DISABLE BOOT FROM USB AND GOTO THE USB SETTING AND MAKE THE USB AS GENAREC AND EVERY THING WILL BE FINE
GOOD LUCK
Jan 04, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
SmaT FAILURE PREDICTED ON HARD DISC
okay you have seen that message simply because it did not detected any hard-disk. If you know how to open your computer all you have to do is press all the wires in there it maybe dew to loose connection. then try booting it up again be sure it has a system already. If still didn't work out no other solution but to replace the hard disk.
Dec 14, 2008 | Toshiba Satellite M30X Notebook
My LaCie big disk extreme+ 1000GB isn't starting and I don't know whats the problem, i doesn't want to boot up. What can I do to get it to start. Its been working fine for a year now and today when I...
Hope this helps??!!
Posted Oct 13, 2006 - It's not the drives that fail, it's the power supplies... They fry after about 3 months-1.5 years. LaCie sells replacements for about $16-$20, dpeneding on the model. We have over 20 of these drives, and here's how you know: the drive spins up, then down - it tries to mount, data transfer will freeze, etc. Just put another power supply on it, and 9 times out of 10, it's fine. Of course, any drive can fry on you, but these have proven to be extremely reliable under some of the hardest use imaginable.
Nov 28, 2008 | LaCie Big Disk Extreme (300797U) 1000 GB...
When you turn the computer on it says SMART Failer predicted on hard disk 0: HTS54108G9SA00-(S1)
S.M.A.R.T. (Self-Monitoring Analysis and Reporting Technology) is a diagnostic method originally developed by IBM that at that time referred to as "Predictive Failure Analysis". This technology was developed for IBM mainframe drives to give advanced warning of drive failures. Based on this diagnostic, Compaq announced IntelliSafeTM, which was submitted to the ATA/IDE standards committees and the resulting standard was named S.M.A.R.T.
S.M.A.R.T. analyzes many of the mechanical attributes; over time, some failures can be predicted by detecting if the hard disk drive is moving out of tolerance. While the S.M.A.R.T. technology can detect upcoming issues, not all hard drive failures are predictable.
All this means on most modern drives is the hard drive is coming close to the maximum tolerances
I usually switch off in the bios smart monitoring.
This system is trying to predict a possible failure, which may or may not occur..
Mar 30, 2008 | Computers & Internet
Computers & Internet Logo
Top Toshiba Computers & Internet Experts
k24674
Michael Thomas
Michael Thomas
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
