Question about Acer (KV.16X04.007) DVD Drive
I have a DVD super multi dl drive and I put a cd and it caused the whole computer to lock up I had to restart my laptop
Posted by jdresow on
Brian Sullivan
  • Acer Master
  • 27,725 Answers
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
Hope this helps
Posted on Feb 11, 2011
My Acer Aspire 7540 DVD Super Multi DL drive suddenly won't accept DVD's anymore
I ran into the same problem and found a program on www.download.com Type dvd repair, this program will fix most issues and worth saving on a flash drive, or hard drive for future repairs.
Jun 20, 2012 | Computers & Internet
Is the 'DVD-Super Multi DL Drive' on the Acer 5742 Aspire basically a DVD rewriter, or does it just play DVD's?
This Super-Multi Drive will write to dual layer DVDs (DVD+R DL or DVD-R DL) at a 4x speed. The full specs of the Acer 5742 are available here: http://support.acer.com/acerpanam/notebook/2010/Acer/Aspire/Aspire5742/Aspire5742sp2.shtml .
You should be able to place a dual layer dvd in the drive and have it recognized. Windows may ask you if you want to format the disc.
I hope this helps.
Oct 08, 2011 | Acer Aspire 5742Z-4200 Notebook
Can't watch blue ray movies on my acer aspire model 5334
Taken from the acer support website.
" Optical media drive 8X DVD-Super Multi double-layer drive:
  • Read: 24X CD-ROM, 24X CD-R, 24X CD-RW, 8X DVD-ROM, 8X DVD-R, 8X DVD+R, 6X DVD-ROM DL (double-layer), 6X DVD-R DL (double-layer), 6X DVD+R DL (double-layer), 6X DVD-RW, 6X DVD+RW, 5X DVD-RAM
  • Write: 24X CD-R, 16X CD-RW, 8X DVD-R, 8X DVD+R, 4X DVD-R DL (double-layer), 4X DVD+R DL (double-layer), 6X DVD-RW, 8X DVD+RW, 5X DVD-RAM
This model of computer does not have a blu-ray drive unless you got a third party upgrade. In this case, you will need to track down special drivers, which can best be done by whomever sold you the drive.
Jun 10, 2011 | Acer Aspire One PC Notebook
I dont have drivers of dvd-super multi dl . non ho i driver del lettore DVD super multi dl.
click start control panel administrive tools computer management device manager scroll down cd dvd rom drives if you see a yellow question mark? right click you will have options to update driver once you have select update windows will ask where to find the driver and if you want to connect to the internet
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers if your computer came with a motherboard disk the driver could be on it
hope this helps
May 11, 2011 | Acer (KV.16X04.007) DVD Drive
Sir i am using acer 4736z i got problem with my dvd driver when i am inserting blank dvd for writing operation it shwos 0 bytes used free sapce 0 bytes not able to write data so what to do pls help me...
you have to make sure you are using the correct format for your drive i.e (+/-)
  • Read: 24X CD-ROM, 24X CD-R, 24X CD-RW, 8X DVD-ROM, 8X DVD-R, 8X DVD+R, 8X DVD-ROM DL (double-layer), 6X DVD-R DL (double-layer), 6X DVD+R DL (double-layer), 8X DVD-RW, 8X DVD+RW, 5X DVD-RAM, 4X BD-ROM, 4X BD-R, 2X BD-RE, 4X BD-ROM DL (double-layer), 4X BD-R DL (double-layer), 2X BD-RE DL (double-layer)
  • Write: 24X CD-R, 16X CD-RW, 8X DVD-R, 8X DVD+R, 6X DVD-RW, 6X DVD+RW, 5X DVD-RAM, 4X DVD+R DL (double-layer), 4X DVD-R DL (double-layer)
  • Read: 24X CD-ROM, 24X CD-R, 24X CD-RW, 8X DVD-ROM, 8X DVD-R, 8X DVD+R, 6X DVD-ROM DL (double-layer), 6X DVD-R DL (double-layer), 6X DVD+R DL (double-layer), 8X DVD-RW, 8X DVD+RW, 5X DVD-RAM
  • Write: 24X CD-R, 24X CD-RW, 8X DVD-R, 8X DVD+R, 6X DVD-R DL (double-layer), 6X DVD+R DL (double-layer), 6X DVD-RW, 8X DVD+RW, 5X DVD-RAM
Apr 09, 2011 | Acer Computers & Internet
Brand new LG portable super multi drive (model GP08NU6B) will not let me write to DVD+RW disks----error says disk is write protected
I have an LG GP08NU6B Portable DVD Drive. Although I can see Videos on the Laptop, when connected, I am unable to get any Audio. Would Appreciate if you would assist in this matter. Tks & Brgds BJ.
Dec 18, 2010 | LG GP08NU40 Super Multi Disk drive DVD...
What is DVD Super Multi DL drive
It means it supports DVD+RW, DVD-RW, DVD+R DL, DVD+R, DVD-R, DVD-RAM, CD-R, CD-RW
Dual layer DVD's have two data layers stacked on top of each other. So instead of holding only 4.7 gb of data it holds 8.5
Thanks and regards,
Jitha
Nov 27, 2010 | Acer (KV.16X04.007) DVD Drive
I have gateway laptop Model ID58, It has DVD- Super multi Dl drive but its LED blinks every time without having any CD. Some time the drive give noise during blinking. If i put a DVD in the drive the...
The drive mechanism is going bad and needs a replacement. Rather than going through the cost of replacement, I suggest you go to Walmart Electronics section and get an Exterior USB DVD drive for about $20-30 dollars. Any easy fix.
Jan 16, 2018 | Acer (KV.16X04.007) DVD Drive
Acer (KV.16X04.007) DVD Drive Logo
Steve Sweetleaf
Steve Sweetleaf
Michael Thomas
Michael Thomas
