You can connect camera's memory card to computer, then download this picture recovery program called asoftech photo recovery which is outstanding among all picture recovery software.
http://www.facebook.com/pages/Asoftech-Photo-Recovery/126127714100611?sk=info
Have you tried this memory card on your
computer?
If this memory card can be read
functionally on your computer, you'd better copy off all your stored data to
another memory card or drive and format this memory card immediately to check
whether it can still be used functionally as before. Otherwise, you have to
replace it.
But, if this memory card unfortunately also
gets the same error on your computer, you'd better try to apply a memory card photo recovery freeware
to get all your stored data back successfully for free:
http://freeware-fix.blogspot.com/2013/04/memory-card-error.html
In fact, this freeware helped a lot as the
camera memory card of my friend was mistakenly formatted. It finally restored all
the needed data of my friend. So, I believe it will also help you a lot.
Try to read more information of this
freeware here:
http://www.freeware-fix.blogspot.com/2013/04/data-recovery.html
After experiencing these troubles, I hope
you can learn a valuable lesson to back up everything important well all the
time.
First of all, do not write anything in to the memory card again. Then try this digital photo recovery software.
Photo Recovery for Windows
Photo Recovery for Mac
Do the following steps:
1: Connect your memory card to a PC.
2: Open the software and choose the memory card where your lost items located, and then scan it.
3: Recover the found files.
It is quite simple.
Remember - Do NOT write anything back to your memory card until you can recover the files safely!
Don't be so worried about ur data. There are some gud data recovery software available on internet. But first of all please stop using d drive anymore to increase d chances of recovering files. Then you need rely on professional data recovery tool. Download the software from the following sites http://www.memorycardrecovery.org and follow the steps
1. Install the software on ur computer.
2. Connect the memory card to computer.
3. select the drive(usually G or H for memory card) , click Start. Now the scanning process will start to search the deleted files. After a while you will then get a list of recoverable files.
4. Press Recover to perform full recovery.
Use Card Data Recovery. It can help you recover all pictures.
