Question about Kenmore Dryers
Kenmore dryer error code 5E - Kenmore Dryers
Posted by byufan24 on
  • 3 more comments
  • byufan24 Feb 11, 2011
    110.85091401
    110.85091401
    There is power to the dryer,I can try to start a cycle but whe I push start, I only get 3 beeps and the "time remaining" light flashes. I did the diagnostic test (more time-->less time-->more time-->less time) it is supposed to show an 88 in the time remaining area, it does not show the 88, it shows 5E, or SE.
    Also, the light DOES turn on and off when closing/opening the door
    I don't know. It says kenmore HE4 on it...I don't know about Elite
Richard Roth
    Top Expert:
  • Kenmore Master
  • 9,472 Answers
What is the model number of your dryer?
Posted on Feb 11, 2011
  • 2 more comments
  • Richard Roth
    Richard Roth Feb 11, 2011
    I could not find a 5E or a SE error for your machine. Does the dryer run and just shows that error? Please let me know what the conditions are that cause the error. Try running the dryer in different cycles and different temperatures to see if you can narrow the error down to a certain cycle. Also, unplug the dryer for a few minutes and plug it back in to see if it will clear the error. Repost and let me know what you find out.
    Regards,
    Rich
  • Richard Roth
    There is a 5E error for a washer but nothing I can find for the dryer.
  • Richard Roth
    IS this a "Kenmore Elite" dryer?
  • Richard Roth
    Richard Roth Feb 12, 2011
    I checked with a friend and he stated that if you can't get into the diagnostic mode that the control board may be bad. I think you have the diagnostic guide but in case you don't here it is. Also, keep trying to get into the diagnostic mode and let me know what happens.
    http://media.fotki.com/1_p,wgfqffqtwbssd...
1 Related Answer
blueextc3221
blueextc3221
  • 15935 Answers
SOURCE: Kenmore (Whirlpool) Elite Electric Dryer
5E - WATER DRAIN ERROR
5E is displayed if the water level frequency detected is 25 KHz or less in the initial phase of the UNB -detecting cycle. The Water Drain error can be cleared by turning POWER SW OFF and back ON.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 30, 2010
My kenmore over the range microwave is showing an error code of 5E or SE . . . What does that mean?
it's the touchpad, you have to stick a new one, call a technician or buy the touchpad corresponding to your microwave oven model
https://www.applianceblog.com/mainforums/threads/51787-Kenmore-Elite-SE-error-code
Nov 05, 2017 | Kenmore Microwave Ovens
WHAT MEANS ERROR CODE FOR MY DRYER MACHINE F11?
if its a Kenmore model then this message says that the button control board has lost sight of the main control board , but its been my experience that this maybe able to be reset and it may never come back or it will not reset and the control board will need replaced (50/50)
cycling power may reset this
Jan 30, 2016 | Dryers
I have a Kenmore microwave with an error code SE or 5E model No: 401.80082700
The SE error code means the microwave has had a Key short error. The control panel or smart board will need to be replaced.
Not really a DIY job. Microwaves can retain up to 2200V even when unplugged.
control panel frame assembly ("control") , which comes with a new keypad already installed lists for $59.99 fyi.
Feb 22, 2018 | Microwave Ovens
When using the dryer I constantly get the 5e error flashing. What do I do to fix it?
An SE is caused by a temporary sensor error. If this error code is diplayed, turn off the power to the washer and unplug it.. After 10 seconds, plug it back in and attempt to restart the washing cycle. If the problem persist, the unit may require service.
Dec 31, 2010 | LG WD-12126RD Front Load Washer / Dryer
Describe your samsung wf-b 1061 error code 5E Problem
Error code 5E is the code telling you that you will need to clean the filter. After you clean the filter the code will go away.
Dec 19, 2010 | Samsung WF317AAG Front Load Washer / Dryer
Kenmore (Whirlpool) Elite Electric Dryer 110.64086201. Diagnostic check generates a 5E fault code. What the heck is that?
Sep 28, 2010 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Michael Thomas
Michael Thomas
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
