Question about Lexmark X1150 All-In-One InkJet Printer
Paper is being fed at an angle - Lexmark X1150 All-In-One InkJet Printer
Posted by ray_bletchle on
Anonymous
  • 428 Answers
This is sort of scenario could be caused by dust inside the printer. Dust prevents the rollers from having a firm grip on the paper while picking paper. When one roller has a firm grip and rolls the paper well while the other doesn't, jam/crumpling results or sometimes paper goes in at an angle. So I will suggest you get a long handle brush and try to reach as far inside the printer as possible and brush (from the back and front; if you have a blower please use it as well). This, if properly done should do it. Brush especially the rollers etc.
Posted on Feb 11, 2011
How do I load paper?
I have a casion hr-100tm calculator and found the easy way to load a new roll of paper. Take a 3x5 index card and cut it on 45 degree angle, then with angle on the right of the machine feet it into the machine pushing it as you go. Once it begins to feed so you can pull on it, then take other end of card, scotch tape to new roll of adding machine tape. As you feed the card through the roll of paper foillows. Once it has fed into machine cut off 3 x5 card. Easy.
The problem is that all rolls of machine paper are not equal and the thinner paper doesn't want to feed. This way it works for any type. Hope it hellps.
Oct 02, 2015 | Casio FR-2650A Calculator
Top feeder won't feed paper straight
Dear
Pl. check the ADF cover locked at both side. Clean the pick up roller with dampen cloth.
Thanks.
Mar 05, 2015 | HP Officejet Pro 8600
When i go to print a doucument, the paper goes in at an angle
take the paper out and try to print something, but look down in where the paper is fed into the printer. Make sure all the wheels are spinning. If they aren't, then thats your problem. If they are working, then make sure nothing is blocking the one side of the paper.
Mar 08, 2011 | Canon Office Equipment & Supplies
The printer only prints half a page then moves to next page and a
Before printing, the printer checks the paper size. If the paper edge guide is positioned incorrectly, the paper may be fed at an angle. If this happens, the bottom of the paper is therefore at an angle and not perpendicular with the paper feed rollers. This can result in the paper sensor not recognising the real page width as it can only detect a certain amount of the bottom of the paper sheet which is nearest to it.
If only part of the width of the paper is detected, the printer considers that the paper width is less than it actually is. To avoid printing on internal parts of the printer such as paper feed rollers, the printer automatically cuts the image to fit the detected paper width As this phenomenon depends on the paper feeding condition, it can be random.
Reload the paper and make sure it is loaded correctly. All the way to the right and the paper guide correctly adjusted.
Feb 04, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Canon pixma ip 1600. paper feed mechanism faulty. will not grab paper and feed through or takes it through at an angle
You said that the paper is fed on one side. Am I right?. If it so,it seems that another material is present inside your printer.
Please check this post for more information
Nov 29, 2009 | Office Equipment & Supplies
Both our brand new copy machines SHARP M316 have problem with the
first thsing to check is the side guides for the paper make sure they are set against the paper being fed through if not the paper will be pulled through at an angle and this can cause your problem you can alson get a slightly heavier paper and put that through to see if you have a jam..did you remove all the packing tags and paper protectors
Jun 15, 2009 | Office Equipment & Supplies
HP L7780 all-in-one prints out of line
if the paper is coming out out-of-align, that suggest the one of the roller need to be replaced.
either call HP to ge a maint. ket or replace rollers. Cost is high compare to the price of the machine.
Jan 27, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
My printer has started feeding the paper through on an angle which is causing ti to jam in the right hand side. The paper therefore does not feed through and printing doesn't happen. My guess is that one...
Clean the pickup rollers with a damp cloth, and dry the rollers with a clean part of the cloth. If it is still feeding paper in scew, then there could be something stuck inside the printer.
May 29, 2008 | Office Equipment & Supplies
Paper jams/ printing blank
Thoroughly check for very small foreign objects in your printer, and check both behind in paper feeder area and inside the unit. Jams can be tiny pieces of paper than have gotten in or torn off paper fed in at slight angle but you may not have noticed. Service you printheads and rollers both manually with solution and cotton buds (q tips) and then see if your ink may be low or out, blocked printheads will obstruct ink from flowing at all. So will damaged printhead points on cartridge, signalling replacement time.
Aug 14, 2007 | HP PSC 1215 All-In-One InkJet Printer
Images coming out crooked when in copy mode. A hardware problem?
Ensure the guide for the plain paper onto which the image is printed, are pushed up fully. It is possible that the paper is being fed into the paper feed path at an angle if the guides are nut pushed up.
Jun 22, 2007 | Brother MFC-640CW All-In-One InkJet...
Lexmark X1150 All-In-One InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Michael Thomas
Michael Thomas
efs_perpends
efs_perpends
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
