Question about Electrolux Epic 6500 Vacuum
Says the bag is full when it's not - Electrolux Epic 6500 Vacuum
Posted by rmadron on
Roger Potts
  • 694 Answers
First try turning dial on top of the machine so the arrow lines up with the smallest dot.
The most likely problem is clogged, worn, or broken control valve assembly (CVA). It could also be clogged tubes to the CVA. This is usually caused by using "made to fit" bags rather than the genuine bags made by Home Solutions. The vacuum would need to be taken to an authorized Aerus Electrolux store for repair/replacement. Generally, if this is the problem, the interior of the vacuum, including the motor, needs cleaned as well.
Some other simple things you can check are:
Dirty afterfilter. This is located on the exhaust hole on the back of the vacuum. To access, press in on tab at back of the exhaust cover, lift cover from the back, and remove filter. If the filter is dark, it is clogged with dust particles and needs replaced. Turn vacuum on and run it for awhile. If it continues to run, this is the problem.
Another potential cause is a clogged hose. Disconnect hose at both ends. Drop a coin down one end and lift that end to allow coin to drop through the other end. If it does, fine. If not, connect hose to the exhaust port, place other end into a large garbage bag, or into the in port of the vacuum, and turn on. This almost always clears the hose.
Check the elbow of the power nozzle where the hose connects. Drop a coin through here to check for clogs. If there is one, it can generally be cleared by pushing it toward the brush with a wooden spoon handle, or similar blunt object.
For nearest store, follow instructions at below link.
http://www.aerushome.com/storelocator/
Posted on Feb 12, 2011
Bag shows full when it's empty. No clog in the hose, but when I start to vacuum, the bag-full indicates FULL, even though it's a new bag.
See if there are any sponge filters that might be clogged. They're usually between the bag and the air flow going to the motor.
Jan 29, 2017 | Vacuums
Outer Oreck xl bag is full of dirt
Make sure that your bag is pushed all the way past the lip on the connector tube and that the "U" shaped part of the plastic assembly is in it's slot behind that lip, or it will not seal properly and you will get dust into the outer bag.
Mar 21, 2014 | Oreck XL2200 Bagged Upright Vacuum
I have the Miele cat & dog S5000 vacuum. I have had it about 1 year and lately the suction doesn't seem as strong and the full bag indicater is always full. I have followed instructions in manual but...
Greetings,
I would say that you have a slight clog in the hose or in the power nozzle somewhere. The full bag indicator is just a guage that will indicate full when it feels like it's lost suction. Example: If you were to take the hose and cover it with your hand, you'll notice that bag full indicator will show full.
To check and see where the clog in the vacuum is, remove the wands and floor attachment so you just have the hose on the vacuum cleaner. With just the hose attached, turn the vacuum cleaner on. Does it still show a full bag? If yes, then remove the hose completely from the vacuum cleaner so it's just the canister part by itself and turn on the vacuum again. If the bag full indicator is now showing an empty bag, this means that you have a clog in your hose.
If the bag full indicator displayed an empty bag when you had the hose on the vacuum, but shows a full bag when you have the wands and floor tool attached, this means that you have a clog in the vacuum either in the wands, or the floor attachment.
For removing clogs from the hose, the quickest way is to just purchase a plumbers snake at your local hardware store, and run the snake through the hose until you find the clog. You may also take a high pressure hose and spray it down the hose until the clog is cleared, but if you use a water hose, MAKE SURE the hose is 100% dry before you use it again.
Also that bag full indicator can be adjusted if you are getting a lot of suction power and it still shows full.
I hope that these suggestions helped you diagnosis your Miele canister to figure out why the indicator showed full. If this helped you please rate my repair helpful.
Feel free to contact me if you need further assitance, I'm always happy to help.
Chris J.
Mar 13, 2010 | Vacuums
Cannister vacuum cleaner bag full sensor faulty.
I'm pretty sure it's not the power supply. If it were, you'd have more problems then the sensor. It sounds like you just need to replace the senor for the "bag full" light
Apr 19, 2017 | Electrolux Vacuums
Bag was full, changed it, the unit now turns off
Try dialing the control valve to the mid way position. If the unit still shuts down with the bag full light on you have a damaged control valve under the dial on the top of the vac.
This valve failure is common in this model and can only be repaired by someone with original AERUS Electrolux repair parts, generally at an AERUS repair shop.
Oct 29, 2009 | Electrolux UltraLux 2000 Bagged Canister...
Stopped working, lights work, shows full light when not full.
Remove the bag and put in a fresh bag. Then rotate the dial on top of the vac to the middle position. When cleaning fine dust the vac will shut off before the bag is full as it is sensing a clogged bag and cannot sense proper air flow through the bag. If this persists the sensor under teh top dial may be damaged and need to be replaced
Sep 08, 2009 | Electrolux UltraLux 2000 Bagged Canister...
13 yr Electrlux.Cuts off if hose plugs in.Says Bag Full-bag empty
This sounds like the valve assembly (full bag control) is faulty or one ov the tubes is clogged. You will have to take it to the shop.
Jul 15, 2009 | Electrolux Guardian Bagged Canister Vacuum
Electrolux Epic 6500SR Full Bag sensor working, Does not Reset properly
The problem was a sticking switch that was not being reset. The vacuum on/off switch mechanism is comprised of two switches. One is the main switch that turns the vacuum on and off. The second is a shut off switch that gets tripped when the full bag sensor is engaged. This second switch is supposed to get reset when you push the on/off switch on the outside of the machine. The full bag shutoff switch was stiff and it, therefore, was taking a couple of presses of the on/off switch to move the shutoff switch back into the running position.
Jun 19, 2008 | Electrolux Epic 6500 Vacuum
Full bag system works properly, but doesn't reset easily
Either there is something wrong with your switch. Which it doesnt sound like it. Take it to your dealer or call another one it sounds like the control valve needs to be replaced. I am a dealer 1-866-966-9350.
Jun 19, 2008 | Electrolux Lux 7000 Bagged Canister Vacuum
Vacuums Logo
Top Electrolux Vacuums Experts
Gerry Harvey
Gerry Harvey
john h
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
