Question about Maytag Neptune FAV6800AW Top Load Washer
My washer won't unlock - Maytag Neptune FAV6800AW Top Load Washer
Posted by tgavello on
FAV6800A FAV9800A
  • 526 Answers
If the machine is FAV6800A or FAV9800A you can release the machine washer top from the base. Just follow the 1st couple of steps in this post Clutch Fix
If you need additional DIY help go to a true DIY forum Google Appliance Repair Forums > Appliance Repair Talk > Washers > Maytag/Magic Chef/Admiral/Jenn-Air
Post your issue there and I will help......D*ick
Posted on Feb 12, 2011
Door won't unlock and the washer will not start to fill.
Check and see if the door is jammed or there is fault in the lock.
Click this link for tips to reset the lock: Door lock
Check the continuity of the door switch and see if the harness connects to the control board to trigger the start cycle when the door is closed.
Jan 21, 2013 | Maytag MHWE200XW Washer
My washer is locked won't open
Will Not Unlock
• Press off. The motor control is not responding if it
takes 4 minutes to unlock. The motor control is
either bad or disconnected.
• Unplug and reconnect power cord. Wait 20 seconds
for machine to unlock.
• Check lid locked switch circuit. Circuit should be
closed at machine control.
• Check for loose electrical connections at lid lock and
at machine control board.
• Push lid closed to make sure nothing from inside is
pressing against it which may keep it from unlocking.
• If necessary, remove clothes by disconnecting power
to washer, and open top cover with a putty knife.Here is the part to order.
Regards,
Richard Roth
http://appliancecafe.com
Nov 13, 2012 | Maytag Neptune FAV9800AW Top Load Washer
My washer spin and unlock button starting flashing and when I try to unlock the washer, it won't let me. I have a feeling the load was off balance. What can I do to unlock it?
Access the drain hose and get the end to ground level in a bowl. Empty any water. Clear filter and make sure drain pump is free. Door will now open
May 19, 2012 | Maytag Neptune FAV6800AW Top Load Washer
Washer won't unlock
These doors are usually on a timer and so won't be released for opening until a couple of minutes have passed by after turning the machine off.
Assuming you've already allowed for this, try giving the door a good firm push (closing) on the mechanism. It may just have caught partially closed.
Apr 28, 2012 | LG WM2455 Front Load Washer
The display reads loc and the machine won't work
Typically to unlock the controls on a Duet washer what ya do is push and hold the END OF CYCLE BUTTON for 3 seconds and the control should unlock
Oct 07, 2011 | Kenmore 3.5 cu. ft. Front Load Electric...
My washer started and now it stopped and it won't cancel/unlock and the door will not unlock. I have tried to unplug and replug and it still will not start or unlock the door. My clothes have been...
the most typical reson the door wont unlock when cycle is finished is because not all the water drained properly due to a blockage in the filter for the drain pump. This tip i wrote explains how to take apart the washer and clean the filter on the pump.
http://www.fixya.com/support/r10121384-check_when_duet_washer_door_locked_after
If you find the filter on the pump to be clear the door lock asm. will need to be replaced.
GENE
Sep 04, 2011 | Kenmore HE2 Plus Front Load Washer
The door on the washer is locked and won't unlock. I have a load of towels in the washer, cannot get towels out. Please help me Thanks
HI - UNDER THE CORNER OF THE SOAP UNIT YOU WILL FIND A GREENISH YELLOW NYLON - PULL ON THAT TO UNLOCK THE DOOR.
Jun 24, 2011 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune FAV6800AW Top Load Washer Logo
Top Maytag Washing Machines Experts
Sheldon Dedek
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
