Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
The garage door open with remote will not close with remote usless you stand under the main opener
Posted by ronwprunty on
Don Maggard
    President:
  • 3,197 Answers
Limited range of your remote controls could be related to radio frequency interference that comes from something in your home or in the surrounding environment. Certain electrical devices can radiate interference; this could be almost anything that is plugged into an electrical outlet.
Please keep in mind that the device can be brand new, or can be an item that has been in use for quite a while. Also, the item may continue to function properly as far as you are able to tell. The only problem with the item may be that it has started to broadcast the interference, with no other symptoms noted.
Some devices are more likely to generate interference than others. This includes TV cable, cable amplifiers, surge protectors, fluorescent lights, battery charging devices (power tools, golf carts, etc.), anything that utilizes a timer (sprinkler systems, lights, alarm systems, etc.), and a myriad of others. If the problem seems sporadic, we can safely assume that the device responsible for the interference is only being operated during these times. Again, please keep in mind that the age of the device does not determine if it is capable of broadcasting unwanted interference. Any electrical device can be the source of the problem.
To isolate potential sources of interference, turn the circuit breaker off to the garage and plug the garage door opener into an extension cord from another room. If the range improves, then the interference is coming from a device in the garage. If no improvement is seen follow the same procedure, this time turning off the circuit breakers to your home, with the exception of the garage and test the remote controls. If improvement is noted, turn the circuit breakers back on, one by one, until the range problem resurfaces. This will allow you to narrow down what room the problem device is in. You will have to go from there to isolate it further, by unplugging and re-plugging the items in that room.
If you are unable to determine any source of interference, then the receiver logic board in the overhead unit will need to be replaced.
Posted on Feb 11, 2011
Digidoor remote
"Another reason is problems with the radio frequency of the remote control system used, some older systems use frequencies that are liable to interference from various sources such as police and fire department radios and military communications. The effects of this interference are many for example, the garage door may open and close on its own or the operating range of your remote control may become so poor you cannot open or close the door with your remote control even whilst standing next to it."
source
Jul 29, 2013 | Audio Players & Recorders
Lift master door will not close with remotes. to close door, the main switch in garage has to be held down until door reaches bottom. when using either remote or main switch, to close said door, the...
Anytime the main light flashes 10 times and the door reverses to the open position it is a door sensor problem. Make sure the small light on each sensor is lit and not flickering. Tweak them a bit. Check the wiring for breaks or shorts. Nothing else will cause this problem.
Dec 14, 2010 | Sears Craftsman LiftMaster Chamberlain...
I have a chamberlain liftmaster formula 1 garage door opener I could able to open the garage door using the remote. How ever I was not able to close it using the inside main panel big white color button....
Check to make sure the sensors in the doorway are pointed at one another and the small light on each one is lit and not flickering. If you cannot get both lights to come on you have a bad sensor.
Jul 12, 2010 | Sears Craftsman LiftMaster Chamberlain...
Garage door only closes halfway
If the main light is flashing 10 times when the door reverses when closing it is a door sensor problem. You can override this with the door control but not with a remote. Make sure the door sensors are pointed at one another and the small light on each one is on and not flickering.
Jul 07, 2010 | Sears Craftsman LiftMaster Chamberlain...
Door will open but not close with remote
The light on both sensors must be on for it to close. Tweak them a bit to see if they are properly pointed at one another. If you cannot get the light to come on you most likely have bad sensors.
Dec 22, 2009 | Sears Craftsman LiftMaster Chamberlain...
My liftmaster 2265 1/2 hp remote does not close
If the door starts to close and the main light flashes 10 times and the door reverses to the open position it is a problem with the door sensors. Make sure they are pointed at one another and they each have a small light that must be on and not flickering.
If it starts to close but reverses and the main light does not flash 10 times it is possibly the RPM sensor which is a small printed circuit board just in front of the motor.
Nov 11, 2009 | Sears Craftsman LiftMaster Chamberlain...
Remote opens door but will not close door (Liftmaster)
If when you try to close the door with the remote the main light flashes 10 times and the door reverses to the open position you have a door sensor problem. Usually it is because one of them has been bumped and is no longer pointed at the other one. If they are pointed properly they will each have a small light that is lit and not flickering. Tweak them a bit. If this doesn't work and the lights are not on you most likely have bad sensors.
Oct 23, 2009 | Sears Craftsman LiftMaster Chamberlain...
Only opens when remotes are close
The problem is in the receiver on the logic board. You will have to replace the logic board. You can get a replacement part at searspartsdirect.com. Thanks BB
Feb 22, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
Top Sears Building Materials Experts
Mike
Terry Smith
Level 1 Expert
Are you a Sears Building Material Expert? Answer questions, earn points and help others
