In many cases the washer will stop draining due to a clogged drainage hose or due to an object caught in the draining pump.
There are some cases when the draining pump is faulty and needs to be replaced.
Washer Drain Pump: small objects or clothes can get stuck in the drain pump. The drain pump must be removed and checked for blockages. If it is clear, but still making noises during the drainage cycle it will need to be replaced.
Clogged Hoses: We usually find socks stuck in a washer hose. The hose is attached to the pump and needs to be inspected. Leaking and damaged hoses should always be replaced upon any signs of wear.
Lid Switch Assembly: This prevents the washer from spinning while the lid of the washing machine is open. If the lid switch assembly fails it will also prevent the washer from draining. A multimeter can be used to test each of the lid assembly units for continuity. No continuity means it needs to be replaced.
Source: https://www.electrafixbc.ca/appliances/washer.html
Hi, i'm pretty sure that this would seem to suggest that the pump maybe faulty or that there is a blockage, arm yourself with a large bucket or bowl and take the drain hose from the machine gently lowering it to below the washing machine tub level, make sure the drain hoseis quite flat or level as you do this, lift the hose if you need to stop the water because the bucket is full, empty the bucket and start again until no more water runs, then set about checking the filter for blockages or anything that maybe fouling the pump, if all is clear then it could be a suspect pump,if not clear all debris clean the filter re-insert it and make sure the drain hose is back in place, try the machine on a cycle,let it fill and see if it empties(pump runs), if not, the machine will not take in any further fresh water or do a main spin because there is water trapped in the machine. so you will have to go through the manual drain procedure again as above and try a new pump, there is also the possiblity it could be the main control board or faulty control loom.
If in doubt look for a washing machine technician that maybe able to give you a free quote.
Hope this helps.
Hello Dorothy - Does the drain pump make a humming noise? If so, there may be a restriction in the drain line or siphoning. Otherwise since it is such a complex unit I would recommend contacting a professional to have either the pump or timer diagnose.
It is possible that the machine does not start off the cycle because there are errors or back feedback from the inputs. For the program to start up the main program controller must initiate the INLET valve to open up and allow water to flow into. If this does not happen then the voltage at the inlet valve must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the dry spin with the drain valve/pump activated so as to drain off all the water from the clothes during the spin.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
