Question about Bosch Tassimo TAS4511UC Coffee Maker
The yellow light stays on even though i put in a new coffee disc... i tried unplugging in and restarting it, and it doesn't seem to work.
  • Marcelo Basile
    Marcelo Basile Dec 31, 2020
    Excellent. It solved for me as well. Just a wet tissue and that is it! Solve me a lot of time! Thanks for sharing!
Anonymous
    New Friend:
  • 4 Answers
Clean the optical sensor that reads the barcode with a non abrasive cleaner. Mine needs to be "wet" before reading the bar code as well as the plastic of the sensor seems to be permanently cloudy. Horrible as it sounds i lick my finger, wipe the sensor and then close the lid. Usually works!
Posted on Feb 26, 2011
  • Michael
    Michael Sep 23, 2017
    Brilliant, thanks sooo much!!!! finger trick did the job and saved me from smashing the machine to smithereens :)
  • Christina Strandlund
    Christina Strandlund Jul 05, 2019
    I'm so glad I read this! I tried it and it worked. I was about to throw my tassimo out.
goldee2532
    New Friend:
Thank you licking the finger thick worked!
Posted on Mar 28, 2015
Why does red light keep coming on after I have used yellow disc to clean
looks the machine wants you to cut down on your coffee enjoyment
what maker and model of machine
Sep 04, 2016 | Coffee Makers & Espresso Machines
Braun 8995 - YELLOW LIGHT STAYS ON!
I experienced the same symptoms on my 8995; solid yellow light (even though the cartridge was full), cleaning failed (red light on) after pressing either start button. After many failed attempts to clean the razor, unplugging the station and pushing start button, I decided to clean the razor under running water. I rinsed the razor under water and then turned it on allowing it to run in a pool of water (like it would in the station). After water cleaning, I returned the razor to the station, pressed the start button and it worked! Was able to do both the quick clean and auto clean.
Jan 06, 2013 | Braun 8995 Electric Shaver
So my gf turned on ps3 selected netflix screen went black now i cant get vido video signal to tv via hdmi or av not even with the two.beep method
apparently the Netflix app wont load if a disc is not present in the drive. it doesn't matter what disc is in it. just ensure you put a disc in and then restart the system before trying to load Netflix again. works like a charm. was just playing around and figured it out. Netflix originally launched with a mandatory disc you had to have in the system for it to work but they've recently scrapped that requirement to the service however it seems the software is just programmed to check for a disc before loading as such you get a blank screen if there is no disc in the console.
Apr 25, 2012 | Sony Playstation 3 (PS3) Console
Water light stays on....no water dispensed, even
My Machine will grind-tamp but will not add water to push through.It will send water out tap on the side.
Apr 14, 2010 | Starbucks Saeco Italia Digital Barista...
New cartridge - toner light still on - will not let me print
Try this...
Power off.
Open front door.
Hold down the 'Go' Button
Power on, while still holding down the button for a few seconds
Finger off, close the door.
Good Luck!
Dec 04, 2009 | Brother HL-2040 Laser Printer
Barely any coffee rises to upper chamber after cooking
It's the gasket!!!!! Store the pot with the two parts screwed TIGHTLY together for about a week. Tighten it up as the new gasket compresses. Problem solved in two weeks or less. Also cook on medium to low heat. High flame seems to make the problem worse.
Jun 28, 2009 | Bialetti Moka Express 6-Cup Coffee Maker
Standby light is flashing
I had the same problem with my machine and managed to get it working again in a few easy steps. This machine is great but it can be VERY tempermental so here are a few tips:
1.The barcode reader MUST be clean or it will not read what the disc is (It is the little glass screen where you place the disk.) If it is not clean the lights will all flash.
2. The little floaty thing in the water container has to be floating in order to keep the machine running- if it won't float, shake it well to dislodge the air pocket that might be jambing it.
3. If the red stanby light won't go away, it is because the disc you are using is either damaged or leaking and it WON'T go away until you replace the disc...(you might have to do it more then once) if that doesn't work- try hitting the reset button on the back of the machine (the little black switch that has a (- and o) as well as unplugging and plugging the machine back in. Lastly, what worked for me was inserting a new disk and only partially clicking in the disk so the 'heating' light came on- leave it like that for about 10 seconds and then very slowly close the disc completely. Hope this helped!
Feb 19, 2009 | Braun Tassimo Espresso Machine/Coffee...
Yellow light comes on to heat water, but does not change to green
I would try opening and closing the disc enclosure latch-- this triggers the machine to re-read the barcode and start a new cup of beverage. If the machine perceives that water needs to be heated more, the yellow light to should flash and the cycle to green when ready. If the water is already hot enough, when you close the latch, it will flip right to green.
Give this a try.
Also see my solution to my own problem with the water reservoir: http://www.fixya.com/support/t1267835-braun_tassimo_model_type_3107_brew
Gazzer.
Jan 07, 2009 | Braun Tassimo Espresso Machine/Coffee...
Cuisinart Coffee Maker Model # DCC-1150
Unplug for longer than 15 minutes to completely reset it
Oct 09, 2008 | Cuisinart DCC-1200 Coffee Maker
Bosch Tassimo TAS4511UC Coffee Maker Logo
Top Bosch Coffee Makers & Espresso Machines Experts
Ross Keen
ADMIN Canada
ADMIN Canada
Are you a Bosch Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
