Set a photo, picture, or animation as a wallpaper (background) image in your home screen.
Download the user guide ..click here .
Do you still have the USB cable with the Motorola Phone tools (PC suite)? if so, you can somehow save them to your computer and then transfer them to your phone later.
2. You need a microSD memory card and a USB cable. If you have both you
can transfer the pictures to the card, then put the phone in memory card mode,
and then transfer pictures using the USB Cable. If your photos are saved on the memory card, you can use a memory card and transfer the photos to your computer and then transfer them later to your other phone from your computer. 3. You need a Bluetooth capable computer.
You can send the file one by one to your computer via Bluetooth. But since your screen isn't visible, your choices are the first two options. I would recommend you the 2nd method. Connect your phone to your computer Via usb cable, watch your computer's screen for any pop ups. If your phone's USB settings is already configured as Mass Storage, you'll see two new Drives in your My Computer folder. One as Phone memory and the other as Memory Card. Open them, find the pictures and save them to your computer (copy/paste). But if you are asked for drivers, it means your phone is configured to connect via Motorola PC suite, in that case, you'll need motorola pc suite software. If nothing happens when you connect via USB cable to the computer, then the USB prompt must have pop up on your mobile screen, use the up-down key and the ok button to select the options blindly. There should be three options, 1. Mass Storage Mode, 2. PC Suite Mode and 3. Printer Mode. If you directly press the Ok button, that means you are selecting the Mass Storage Mode (no.1), if you press the down key once and press Ok, then it would connect as Pc Suite Mode... and so on... Actually, if you don't have much idea about transferring media from phone to computer and vise versa, the best method is using the Pc suite. Most importantly, if your photos are saved on your memory card, you better use a Card Reader and transfer them to your computer so that you can do whatever later.
If your phone screen functions, you have three options..:
1. Motorola Phone Tools: If
you are interested in making your own ringtones and backing up your contacts to
your pc this is probably the best route to go.
These are the idea I could share about your problem. Since menus and views are customizable, it's not 100% successful even if you refer another similar phone to navigate through the menus and folders, you may even have more or less or different folders other than what the other phone has.
Let me know if you need further help.
Good Luck.
Thanks for using FixYa.
Welcome to Fixya
Black screen is caused by broeken flex. Flex is a part that connects the upper part ( screen) and the lower part (keypad) of the cellphone. the flex is a common problem with flipflop phones. It costs around $14-15 including labor.
Thank you for using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
If the front and back screens are lit up white, or
both are black, then it is the flex ribbon. you can purchase one with
tools on ebay for around 5 bucks
Else it is the screen or just a backlight problem that can be verified only at service centre.
the screen is black i can't see where i am going
my screen is black i need to get my pictures off i need step by step directions it is a motorolakrzrk1
I have a motorola krzr k1 the screen is black s i can't see where i am going i need step by step directions to get to my pictures and step by step directions to get them off and to get them on my other phone or to my laptop
both screens are black it turns on but i can't do anything because i don't know where i am i went to the att&t store they told me if i could find another krzr phone we could use that to follow the way to the pictures and put them on my new phone but i can't find another one if i can just get the directions i might be able to get them off what i mean i push centerbutton push right ket up key and so forthj
the advice they gave did not help
this is not helping me
this did not help me
