SOURCE: SIR-S4040R will no longer power up (except the fan)
hold in the power button for at least 10 seconds. It should reboot. If not the DVR needs to be replaced.
SOURCE: Set Up for DVR
Hello: If you have only one incoming cable, just hook it up on SAT 1. What happens is that you will only be able to record what you're watching. If you want two incoming cables, just change the LNB to a dual LNB if you have a round dish. If you have an oval dish, most likely has a multiswitch LNB, so all you need to do is hook up another cable to that LNB and run it to the receiver and put it on SAT 2.
This way, you can watch one program and record another program on a dif. channel at the same time. Either way, you need to take out the LNB from the dish for one or the other option. It's best to contact your service provider and get a tech, to do the changes. It's not costly.
SOURCE: Want to run my dtv receiver through new digital converter box.
You have to subscribe to DirecTV service in order for it to record. Unfortunately, you have to have the DVR feature activated (with the fee) to record, The hardware will only get DirecTV channels, no analog channels. What you are trying to do will not work.
SOURCE: Find remaining recording space on SAMSUNG SIR-S4040R
You will have to "Find space" by deleting something/anything to make "space" for "New" material. Basically it is trying to tell you the drive is filled up and ya need to either delete or cut & paste away to some other media, some data, to get more space to record more stuff. OK?
