Question about Sony PlayStation Portable (PSP) Console
I have tried solution no.1 but the paper was stuck with the memory card. how to take it out. HELP.!
Posted by aqilah_fuad on
Eddie Chen
  • 661 Answers
Solution #1...? Anyway, I'm guessing that your problem is that some paper is stuck in your card slot. Lol. I'm going to assume the paper is wadded up. Most tweezers wouldn't fit in a memory card slot, so use something small and pointy(i suggest a toothpick; one of the sturdy ones, not the cheap ones that break like paper matches) to fish it out. Don't use anything metal. you might damage the contacts. BE CAREFUL.
Posted on Feb 11, 2011
Can't get my memory card out of my sony ericcson cedar silver phone J108
In some devices its push-n-go functionality. Try to push the mem card gently, and see if it comes out slightly.
Else if card is stucked then try forcep it will help you to take out the card.
Dec 26, 2011 | Cell Phones
HELP!
Paper clip preferable plastic I'll help the card out, or some fine pair of tweezers will work perfectly.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Dec 11, 2011 | Brother DCP 115C All-In-One InkJet Printer
I own a Casio Exilim and every time I turn it on it says lens error and the lens constantly get stuck. Please help with this problem.
Hi there please follow the steps and let me know the result.
1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine . Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec .. in not done the press both Menu & self time key for 2 - 4 sec.
i hope it will gives you success. Thanks
Jan 17, 2011 | Casio EXILIM Card EX-S770 Digital Camera
Paper is getting stucked in the canon printer
Just clean the print head and also ensure that the paper is placed proprely and no other piece of the paper is inside it . Most probably cleaning the print head willsove yur problem
Thank U
Please rate my solution as it wil cost u just one click
Nov 05, 2009 | Electronics - Others
Sony memory stick is stuck in SD slot on my HP Pavilion dv7-1279
First, with the battery removed, a tweezer or thin paper clip.
Sep 22, 2009 | HP Pavilion dv7-1279wm Notebook
HP C5180 All-in-one : Memory Card Error, No memory card in it
  1. Remove the memory card from the camera.
  2. Locate the memory card slot on the product that is compatible with your memory card. Figure 1: Memory card slot locations c01331721.jpg 1 - CompactFlash (I, II) 2 - Secure Digital, MultiMediaCard (MMC), Secure MultiMedia Card 3 - xD-Picture Card 4 - Memory Stick, Magic Gate Memory Stick, Memory Stick Duo (with user-supplied adapter), Memory Stick Pro 5 - Front universal serial bus (USB) port (PictBridge-enabled)
    NOTE: Some portable USB flash drives with a read-only partition, such as U3 smart drives, might be incompatible with the front mass storage port on your product. These partitions are added by the manufacturer and may include utilities and other software. Refer to the manufacturer for additional details about your drive.
  3. If it is not already on, turn the product on by pressing the power button (c01324469.gif ).
  4. Turn the memory card so that the label faces inward and the contacts face the product. Figure 2: Inserting the memory card c01335108.gif CAUTION: Inserting the memory card in any other way might damage the card and the product.
  5. Gently push the memory card into the memory card slot until it stops. The memory card does not insert all the way into the product; do not try to force it.
  6. When the memory card is inserted correctly, the status light next to the memory card slots flashes and then remains solid green. CAUTION: Never attempt to remove a memory card while it is being accessed. Doing so can damage files on the card. You can safely remove a card only when the status light next to the memory card slots is not blinking. Do not pull out a memory card while the light is flashing green.
Step two: Print the photo
  1. Press Photo Menu . A message displays on the control panel with the number of files found on the memory card.
  2. Press the right (c01185072.jpg ) and left (c01185108.jpg ) arrow buttons to browse through the photos on the memory card.
  3. When the photo number you want to print appears, press OK .
  4. After selecting the photos, press Photo Menu again.
  5. Press the right arrow button (c01185072.jpg ) to select Number of Copies , and then press OK .
  6. Press the right arrow button (c01185072.jpg ) to select Layout , and then press OK .
  7. Press the right arrow button (c01185072.jpg ) to select Paper Size , and then press OK .
  8. Press the right arrow button (c01185072.jpg ) to select Paper Type , and then press OK .
  9. Make any other appropriate changes to the settings, and then press Print Photos .
May 23, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
Constant Initialization
i would start by removing all paper trays, optional memory, network card, etc to see if it boots up then.
Mar 12, 2009 | HP LaserJet 1600 Printer
Sony Cyber-Shot DSC-T5 "C:13:01 Format Error"
I had the same problem, you can solve this by:
1. Push the card multiple times in/out the slot or
2. Use a little bit of contact spray on a small piece of tissue, rap this in the length around the memory card just 1 time. Be carefull not to make it to thick that it get stuck in the slot. Then push the card multiple times in/out the slot or
3. Cut a small strip of waterproof sanding paper (grain: 400 or more - the surface feels just like paper, and is just a thin as paper) just as wide as the card or slot. Cut a strip of plastic (eg.old credit card) also just as wide as the card or slot. Rap the sanding paper in the length of the strip and insert this in and out the slot. But!! ... make sure you stay at the upper side of the contacts, don't worry just do it carefully, don't use force and sand the contacts a couple of times. This way work for me, finally!!
Oct 31, 2008 | Sony Cyber-Shot DSC-T5 Digital Camera
The memory card is locked and I cant figure out how to unlock it...the camera wont take pictures and cant even erase the pictures
remove the memory card and look on the side of it their should be a little tab move it to the other possion and try the camera again. if that does not work with the card out gently tap the camera on the card side. and reinsert it their is a sensor that tells the camera their is a card inserted in it. it might be stuck. hope this helps.
Apr 24, 2008 | Cameras
Sd card stuck in memory reader of toshiba laptop
I had the same problem, read some of the proposed solutions and came up with one that worked for me! Here it is: (1) cut a piece of duct tape that is about half the width of the slot and a couple of inches long (2) use a small flat head screwdriver and depress the card down, so that a small gap is created above the card (3) take a second small flat head screwdriver and force the tape into the gap above the card - adhesive side towards card (4) continue to work the tape into the gap so that it covers as much of the card as possible (5) remove the screwdrivers and gently pull on the tape until the card is removed!
Apr 01, 2008 | Computers & Internet
Sony PlayStation Portable (PSP) Console Logo
Top Sony Video Game Consoles & Games Experts
Daniel Dollive
Daniel Dollive
Steven Wander
Steven Wander
Raj Patel
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
