Question about Micro Innovations Wireless Keyboard/Optical Mouse 12600764
I have a Micro Innovations wireless mouse and keyboard but no manuals or setup disks - when I hook up the mouse it works fine but I get no response from the keyboard. Is there just the one remote for both pieces and is the lack of response from the keyboard due to lack of drivers? thank you.
Johan Erasmus
    New Friend:
  • 122 Answers
There is one receiver unit. Check that you removed the piece of plastic between the battery and terminal in the keyboard. If it still does not work, remove the batteries and put them back. If it still fails, try plugging the receiver into another usb port
Posted on Feb 03, 2018
5 Related Answers
Anonymous
SOURCE: Keyboard connectivity
Yes the voltage on my keyboard has to be 1.5v or greater per cell to get it to work well with my keyboard. Fresh alkaline won't hold 1.5v very long. And I like rechargables and they never get to 1.5v per cell. So I added a third AA battery and run rechargables. Now it works until the cells drop to 1.0v each.
Posted on Aug 14, 2008
Anonymous
SOURCE: Micro Innovations KB1045SLR Wireless - half the keys dont work...
LETS SUE MICRO INNOVATIONS!!
Posted on Sep 20, 2008
Anonymous
  • 8637 Answers
SOURCE: micro innovations wireless keyboard and mouse
Make sure the mouse batteries are good. then,
Normal 0 Turn the mouse over and find the smallrest/connect button on the bottom of the mouse and press it toReset/Connect the mouse to the receiver and work properly.
If not, try pressing the receiver button and then pressthe mouse. This should be done whenever you change batteries orglitch.
Hope this helps you. Bud
Posted on Jan 20, 2009
Anonymous
  • 724 Answers
SOURCE: Micro Innovations wireless keyboard and mouse, keyboard not worki
Does the wireless keybourds need software to see the the transever when it is in the keyboard connection? Sort of a driver for the transiever
Posted on Jul 28, 2009
Anonymous
  • 82 Answers
SOURCE: I moved my computer to another room and after the move the mouse
Have you tried pairing them??? Press the button on the transceiver til the light flashes and then in turn press the mouse pair button followed by the keyboard pairing button. See if this fixes it
Hope this helps
Mark
Posted on Aug 24, 2009
Testimonial: "The problem was I couldn't locate the pairing button on the keyboard but I found it just before I received your email. Thanks for the fast reply"
Do i need a keyboard and a receiver for the mouse to work and if not how do i hook it up
Your wireless mouse and Keyboard work with the same wireless transmitter that is plug in into a USB port.of your computer. You can use the wireless mouse with that USB transmitter and dont use the wireless Keyboard. If you need a keyboard you can get one to be plug in into a USB port with the wire attach to the keyboard.
Mar 23, 2012 | Micro Innovations KB982W-F Wireless...
I have a micro kb985w mouse and key board and they are not working. How do I fix the problem? Thank you
1.check all batteries.
2. press the connect in the proper sequence. base, mouse , then base, keyboard. (should be listed in the manual) sometimes its base, mouse , keyboard.
3. hook up a old keyboard to boot into windows before you try using the keyboard mouse. (you can run two sets at the same time without an issue)
Aug 25, 2010 | Micro Innovations Wireless...
I have a Compaq computer and keyboard and a wired Micro Innovations (mini) mouse. I also have a Micro Innovations wireless optical mouse. How do I hook up the wireless to work?
For the wireless mouse to work with your computer, make sure that it has a bluetooth capability in it. This is how your computer will communicate with your wireless mouse. If it does not have bluetooth, see if your wireless mouse came with a bluetooth dongle. If it does, connect the dongle, download the driver and the pc should detect your wireless mouse.
Let me know if you have any questions.
Hope this helps!
May 12, 2010 | Micro Innovations KB982W Keyboard
Micro Innovations PD7250LSR Wireless RF Laser
I believe this is the company responsible for the software and anything to do with the company who made the product with the Micro Innovations name. http://www.avail-software.com/
Oct 30, 2009 | Micro Innovations PD7250LSR Wireless RF...
I hae a MI wireless keyboard and mouse but lost
hello,
Here is the link to download manual where you can find step to step directions
http://static.tigerdirect.com/pdf/Micro-Innovations-KB990W-UM.pdf
Sep 03, 2009 | Micro Innovations Wireless...
Jul 28, 2009 | Micro Innovations KB1045LSR Keyboard
Micro innovations wireless keyboard and mouse
May 15, 2008 | Micro Innovations KB985W Keyboard
Problems with Micro Innovations Keypad and mouse wireless
I don't have the manual or the cd and I have replaced the batteries in both the keyboard and the mouse, but they will not work. when i go to control panel and look at mouse and keyboard settings, it says they are both installed and working properly. Any suggestions?
Apr 25, 2008 | Micro Innovations PD7250LSR Wireless RF...
GOt the same keyboard and trying it right now, and must say feel kind of weird and I'm a good typer. Sometimes keys won't work, then you have to press them several times and then they work and it's like it never was a problem; this looks to me like a reception/processing problem, not mechanical in the keys themselves. Mouse is OK so far, just don't like the feel of the two side buttons (back and forth) on the left, because they feel wobbly and screechy and cheap, not comfortable.
Mouse roller is good, and keys on the board have a soft sound when you type, both things that I like. The keys are like notebook keys. And the board is nice and small and sleek, and takes up a lot less space than the wireless logitech combo I also have.
Apr 02, 2008 | Micro Innovations KB982W Keyboard
TO EVERYONE HAVING PROBLEMS WITH THESE MICRO WIRELESS KEYBOARD & MOUSE.. IM ON MY SECOND ONE NOW TOOK THE FIRST ONE BACK, CAUSE IT STOPPED WORKING WITHIN HOURS. SECOND ONE STOPPED WORKING WITHIN A WEEK.. EITHER THE MOUSE OR THE KEYBOARD.. ANYWAY, I THINK 99% OF THE PROBLEMS ARE THE BATTERIES!! THEY SEEM TO BE VERY ******* ALKALINE BATTERIES. I HAVE SWITCHED TO LITHIUM BATTERIES, AND SO FAR SO GOOD!!!
Feb 28, 2008 | Micro Innovations PD7250LSR Wireless RF...
Micro Innovations Wireless Keyboard/Optical Mouse 12600764 Logo
Top Micro Innovations Computers & Internet Experts
Michael Thomas
Michael Thomas
Mike
Are you a Micro Innovations Computer and Internet Expert? Answer questions, earn points and help others
