Recent Windows 7 installation has left me with a non-compatible printer ie printer does not respond to new programme
Posted by dajackson251 on
Anonymous
  • 4,323 Answers
Hi
Please let me know the make and model # of the printer to assist you further. If it is not compatible with Windows 7 then you can uninstall it and install the Windows you were using earlier with which the printer was compatible. Hope this helps...please post back for further assistance.
Daniel
Posted on Feb 11, 2011
Installed HP deskjet 890c printer to new windows 7 laptop - purchased new usb printer cable - will not print from laptop but will print test page from printer
Before we conclude that cable is faulty, we have few things that need to be checked.
  • In the device manager check for "Other Devices" and expand it, you may see an device with exclamation sign on it. Right click and uninstall the device.
  • Disconnect the printer USB and reconnect it back.
  • Windows 7 detects the hardware and automatically installs the correct driver.
Note: When you connect the USB cable to the printer, and then to the computer, Windows 7 activates Windows Update. Windows Update searches online for the most recent product driver on the Windows Update site. If the online driver is more recent than the driver stored in Windows 7, the computer downloads and installs the updated driver.The Windows Update process takes place automatically. Therefore, you might not notice that the process is in progress.
If you dont see any notification on connecting the printer, try plugging to different USB port.
If non if these works, replace the cable.
Good Luck!!
Feb 07, 2012 | HP DeskJet 890c InkJet Printer
Can't get my Epson 880 inkjet to work under Windows7... Epson and Microsoft both say it is compatible. But all I get in Printer and Devices is a USB Printer ICON with an yellow&black exclaimination...
Epson's support ends at Windows 32 bit for your device . Your printer will not run under a 64 bit system .
There is no direct solution to this issue .
If you have a Windows XP install disc , you can install a virtual version of XP on your machine with http://download.cnet.com/VMware-Player/3000-2094_4-10470784.html or via Microsoft's if you are using Ultimate or Professional .
Otherwise , you will have to purchase a new Windows 7 compatible device .
Best regards ,
fanaudi .
Aug 26, 2011 | Epson Stylus 880 InkJet Color Printer
Trying to install printmaster 95 on my windows 7. error message appears that it is non compatible with 64 bit. is ther a patch available to make pm 95 compatiable with 64 bit? any suggestions around...
Title: trying to install printmaster 95 on my windows 7. error message appears that it is non compatible with 64 bit. is ther a patch available to make pm 95 compatiable with 64 bit
First of all download compatiable driver for that printer for win 7and install it
May 08, 2011 | Computers & Internet
I have installed the printer on my new laptop which runs Windows 7 Pro 64bitversion. It does not work. I have downloded various "driver update" programmes all of which tell me there is nothing...
You should have a HP Laser Jet 4 printer driver included within the Add Printers Wizard on Windows 7, use this printer driver it will be 100% compatible with the 9114 as this is a PCL5e printer driver and the 9114 supports the PCL5e emulation.
Dec 29, 2010 | Tally T9114 Laser Printer
I have a Dell 944 all-in-one printer and just got a new Toshiba laptop. The new laptop uses Windows 7, which is not supported by the printer. Is there an update to the drivers & utilities to make...
Did you try the Vista drivers in the compatibility mode. Drivers and instructions can be found at...
http://en.community.dell.com/support-forums/peripherals/f/3528/t/19306932.aspx
Let me know what happens.
If using Windows 7, use the Vista drivers in the compatibility mode.
Right click on the setup.exe file, left click properties, left click compatibility. Change the compatibility to Vista(Try Vista SP2). Then install the proper drivers. You'll be prompted when to connect the printer(powered on)
***To install drivers, sometimes the file unzips and does nothing. You have to look for the setup.exe file, right click on it, then left click run as administrator***
As for scanning, if you have the disk that came with the printer, then insert the Printer disk and stop it from running. Go to My Computer and double click on it. Look for the drive with the Dell disk in it. Right click on it, left click explore. Look for the OCR Folder. In the OCR Folder, there is an Abbyy Folder. right click on setup.exe, that's in the Abbyy Folder and left click run as administrator. This will install the OCR program.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Dec 09, 2010 | Dell 944 All-In-One InkJet Printer
I'm trying to run my Hypertech ECON programmer for my 2010 Silverado, when I install the disk it gives me a error code 2869 and exits me out of the install. Am running WIndows 7
It seems that Windows 7 is not compatible with this program and thus the error 2869.
1.run the program in the Program Compatibility Assistant utility in Windows 7.
then select the caption that says it ran on a previous Operating system ( that is Windows XP/ Vista etc. and select the radio dial to the left and click apply.
Instruction from Windows help:
Run the Program Compatibility troubleshooter
Click to open the Program Compatibility troubleshooter.
Follow the instructions in the troubleshooter.
If you cannot install a program, insert the installation disc for the program and, using the troubleshooter, browse to the program's setup file, usually called Setup.exe, Install.exe, or something similar. The troubleshooter is not designed to work on programs that have an .msi file name extension.
Sep 25, 2010 | Computers & Internet
My computer runs windows 7, will the PSC 1210 printer be compatibke
Hello and Welcome to FixYa!
Yes the Printer is compatible with Windows 7 both 32bit and 64bit, you can install the printer on Windows 7 without any eternal driver source, the drivers for this product model are already included in the Operating System, all you have to do is;
  • Turn the product on.
  • Connect the Universal Serial Bus (USB) cable to the printer, and then to the computer.
  • A Your devices are ready to use window might display on the screen.
Note: When you connect the USB cable to the product, and then to the computer, Windows 7 activates Windows Update. Windows Update searches online for the most recent product driver on the Windows Update site. If the online driver is more recent than the driver stored in Windows 7, the computer downloads and installs the updated driver.The Windows Update process takes place automatically. Therefore, you might not notice that the process is in progress.
If you got any Questions/queries, do ask us, we are here to help.
If you think I was of help, your token of appreciation in the form of rating will be esteemed.
Concerned, Nooh
Aug 06, 2010 | HP PSC 1210 All-In-One InkJet Printer
I have a new computer with windows 7 and I can't download my old palm installation cd
Check your PDA manufacturer's website if it is compatible with Windows 7. Even my recent Palm doesn't pass compatibility with Windows 7.
Nov 07, 2009 | Palm TX Handheld
Kodak 5300. I cant get the installation disk to run on windows 7
As far as i know there is no compatible software for your printer for Windows 7 at this time.
Try to visit this site for the latest software of Kodak
www.kodak.com/go/aiodownloads
Aug 30, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
k24674
